6 Pages<12345>»
#41 Posted : Wednesday, 21 December 2016 10:11:00 AM(UTC)
Was thanked: 27 time(s) in 26 post(s)
What you have mentioned Lingus are normal options available, well documented and advertised. The Ambulance was a "special" work car so they probably thought that ambo officers deserved more than a spartan 1 tonner. But it is documented that you could order them. When you get the guy who then comes out and tells you he has a non ambulance tonner with the Premier front because he the original owner wanted it and Holden built it.
And as Byron said, the GTS options, you could order a Belmont/Kingswood/Premier with many of the standard features of a GTS such as Bucket seats, sports instruments, engines (186S, V8s) 4 speed gearbox, disc brakes, console shift for auto, wheels and hubcaps and so on. But you could not order the guards, bonnet, steering wheel (except in HZ). Some package cars got them, but that is the nature of package cars.
Warren
castellan Offline
#42 Posted : Wednesday, 21 December 2016 10:19:21 AM(UTC)
castellan
Originally Posted by: Lingus Go to Quoted Post
Given what HK1837 has indicated, this Kingswood is pretty much equivalent to a Monaro GTS 350, but with four doors and no black paint accents ... with the sedan sharing the same wheelbase as the coupe, I guess all parts are a natural fit, and I'm guessing also that the four 350 wagons mentioned in the AMCS listing would have simply adopted a Statesman De Ville 350 exhaust system, both vehicles having shared a common longer wheelbase.
Thanks also for mentioning the HQ Monaro LS option with 350 engine ... correct me if I'm wrong, but in a normal dealer sales procedure the LS '350' was not available with a 4-speed manual transmission ... I'm also of the notion that, regardless of transmission choice, the HQ Statesman Custom (I always thought of them as a long wheelbase Kingswood sedan) was not normally available to order with a 350 engine option.
The GTS350 manual sedan would have got over this:
Dual exhaust.
U21 instruments with 140/225km/h speedo.
GTS coupe's suspension and sway bar (but not the fast ratio steering from memory - I missed this in my last post).
GTS trim.
Paint and blackout treatment.
You are correct, this sedan would have simply used GTS350M coupe bits to make everything fit, and also correct the LS was auto only with 350. Statesman was available with 350 IIRC but as a retail order only, would not be a dealer bank vehicle, but then again neither would a 308 example - you'd have to order that too. I think there was at least 1 x L31 M21 Statesman made, and also recently another 1 of 1 car turned up - an L30 M41 HQ V8 Monaro (80437).
That L31 M21 Statesman that I know of was a QLD Government bought new car for Aboriginal services department Maryborough who lived in Hervey Bay for Aunty Frances and Uncle Lenny owned it and it was purple and got sold by Lenny at Underwood, where the Dealer argued with him that he had put the 4speed in it and Lenny said no no no it came with the 4speed from new, the dealer said to try too sell that Statesman he would have to put an auto in it.
It had orange blinkers so it was a 1973-4 car and they had another Statesman the same colour with white blinkers, not sure if it was a 4speed.
Back in them days the Premer Joh Bjelke truly did look after Aboriginal people well and the media and ALP were just full on spinning slander and lies.
And the moronic communist principle of the school had a HQ Statesman 202 with 3 on the tree, so if you worked for the Government as a person holding a senior position I would say that they had all such information come floating on there desk with a great deal on finance payments etc.
detective Offline
#43 Posted : Wednesday, 21 December 2016 9:58:33 PM(UTC)
detective
..so are we in agreeance that a perceived "factory built special" is more than likely a "dealer cobbled" new car, with the myth of being "factory built" perpetuated from the day it was sold by a fast talking dealer / salesman to a very unsuspecting, wide eyed purchaser ??
Edited by user Wednesday, 21 December 2016 10:01:22 PM(UTC)  | Reason: Not specified
Silverfox Offline
#44 Posted : Wednesday, 21 December 2016 10:51:50 PM(UTC)
Silverfox
Detective.
This car was factory built. End of story.
Regards
Nick
Lingus Offline
#45 Posted : Thursday, 22 December 2016 12:05:04 AM(UTC)
Lingus
Originally Posted by: Silverfox Go to Quoted Post
Detective.
Regards
Nick
Factory built is always going to be easier to confirm than what a dealer may have done after manufacture ... the build plates on the car tell a story, as does the original Owner's Manual / Service Manual, as does an original customer copy of the Offer to Purchase ... and you can also apply to the manufacturer for a letter / certificate of authenticity.
As for special build cars from Holden, I recall Modern Motor magazine commissioned the build of a unique car in 1968 and followed its progress along the Elizabeth assembly line ... I have the particular magazine tucked away somewhere, but one of the unusual aspects of manufacture reported in the magazine story involved manually cutting into the floor pan to facilitate fitment of the transmission ... the car was a HK Premier station wagon optioned with the 5-litre (307ci) V8 engine and a 4-speed manual transmission.
I've also read input at other forums from a fellow who apparently owns 16 Brougham sedans from across the HK-HT-HG series ... he has suggested that the 350ci Chevrolet engine was factory fitted to some Brougham cars of both the HT and HG series and that he owns one example of such in a HT Brougham sedan.
#46 Posted : Thursday, 22 December 2016 5:22:38 AM(UTC)
Things like engines and transmissions are going to be on the tags if they were factory fitted. I don't think there was any dispute that the car in this thread was a factory built car. I think the story as how it was ordered was of intrigue.
#47 Posted : Thursday, 22 December 2016 5:31:51 AM(UTC)
Not on this car. Remember it is an earlier 1972 HQ V8 Kingswood, that is all the plates tell you.
#48 Posted : Thursday, 22 December 2016 5:35:55 AM(UTC)
Detective.
Regards
Nick
This car is earlier 1972 so no detail on plates.
I don't think that HK wagon had any non-standard options IIRC. It was a special order build and yes the tracking of the fabrication of the car by the magazine was very unusual, but almost any 307 4spd HK outside of GTS will be special build.
That Broughmaro or whatever it was called built for the Motor Show scene was essentially a GTS350 in a Brougham body. Fluted buards, 10-bolt etc. You can see it roped off in the Holden display in a few photos.
#49 Posted : Thursday, 22 December 2016 9:32:08 AM(UTC)
That Premier wagon was ordered by Modern Motor magazine as their run around car and as Byron said, all options were straight out of the option book for that car, anyone could have ordered the exact same car. A large number of cars turn up with interesting combinations, that are straight out of the available option list for that vehicle and then people start making out as if it was something even more special.
What you have to remember is what Byron has already pointed out, all cars must be ordered and then added to the schedule. The schedule is set weeks if not months in advance. If you are making 200 cars a day you have to plan all the parts for those 200 cars well in advance, from the panels, trim, engine, gearbox etc. (Holden has stopped V6 engine manufacture but every one of the stockpiled engines has already been assigned to a car, so you would no longer be able to order a V6 Commodore you will have to take one from the scheduled). So in most cases the dealers rang around and found a car that was close to what you ordered.
A friend of mine ordered a Blue HJ Kingswood, 308 auto, sports dash. He did a lot of caravaning etc and ordered his tow vehicle. When it arrived a week later it had bucket seats and T bar as well, he did not want buckets so the dealer through them in for free.
My dad purchased a HQ Kingswood when they first came out and he waited months. He ordered a White wagon, black cloth trim, headrests, 253, trimatic, 3.55LSD, 6" rims, superlift shocks, Sports Instruments.
The option game was well on by HQ and some dealers embraced it and there are some real nice cars out there. Real "Personalised" transport.
Warren
Tour Director Offline
#50 Posted : Thursday, 22 December 2016 11:20:02 AM(UTC)
Tour Director
There are many people who worked for GMH and had enough clout to order cars with what they wanted on it. After 10,000 k's the cars were turned over, often to family or friends who were in the know. Even parts suppliers could get cars through GMH as they had their own person handling the ordering and sales.Earl Peppin was based in Melbourne and he was the master of the game. Often cars offered were a lot lower in travel as some execs just ordered a larger car to suit for the holidays then reverted to a smaller car. It all depended on your position and pay rating as to what you could get away with. They did this with cars to increase their published registration numbers and is a practice some companies still do today. They are either fleet or demo cars just to increase their numbers. I know one GMH person who ordered a VP Wagon with everything just to suit his wife's dogs going to shows.
#51 Posted : Thursday, 22 December 2016 12:07:00 PM(UTC)
I remember that article well & how they made a huge deal about them having to cut the floor pan for the Saginaw shifter. But I believe that all HK/HT/HG floor shift holes were manually cut, other than perhaps those pressed especially for GTS production.
Virtually all HK/HT/HG floor shifts that I've seen have been oxy cut & this is the case with Fords of that era also.
Edited by user Thursday, 22 December 2016 1:06:26 PM(UTC)  | Reason: Spelling
Lingus Offline
#52 Posted : Thursday, 22 December 2016 12:49:22 PM(UTC)
Lingus
Warren
Similar circumstances occurred with my father when he purchased his new Holden in late 1978, having previously had the use of a regular diet of Holden company cars since the early 1960s. His final company car was an automatic 1977 HZ Kingswood SL wagon in Atlantis Blue, featuring the 4.2 litre V8 and aftermarket (under dash) air conditioning.
When it came around to starting his own business in 1978, he sounded out a dealer for a new HZ Kingswood SL wagon in his chosen colour of Jasmine Yellow ... he was always looking to save a buck, so I was a little surprised he specified integrated factory air conditioning, but other than continuing with a column-shift auto, he wasn't interested in any other options and I also couldn't convince him to consider the small V8 of his previous company car ... the dealer found a six-cylinder factory-air Jasmine Yellow wagon in local stock, but it had a console floor-shift automatic and power steering ... and that's what he ended up taking delivery of, without paying for the options he hadn't originally specified.
Edited by user Thursday, 22 December 2016 12:57:20 PM(UTC)  | Reason: grammatical error
detective Offline
#53 Posted : Thursday, 22 December 2016 9:42:24 PM(UTC)
detective
...which makes the whole notion of a factory built "special" car even more incredulous. They were ordered just fine, but ultimately fitted out by the servicing (and ultimitely warrantied) show room dealers ....
I have purchased two brand new cars in my life .. An XF Fairmont Ghia wagon in 1987, and the very late build CV8-Z in May 2006.
...I could not get "premium sound" on the XF Ghia being a wagon, and the CV-8Z was a dealer purchased car for the summer months into 2006 ....A show off car till Winter kicked in...then the dealer principal at Preston Motors tipped her out. In no way was it a Demonstrator as that model/series was quite finished at that point.
#54 Posted : Friday, 23 December 2016 6:25:48 AM(UTC)
Fair enough. What shows it's factory installed 350? Excuse my ignorance.
#55 Posted : Friday, 23 December 2016 9:07:54 AM(UTC)
The car comes up on Holden records as a factory 350 engine and 4 speed gearbox. It also has the books, however in saying that if the microfiche records for the HQ did not exist then this car would most likely be consider a mock up, as today it is so easy to reproduce owner manuals with the details that you want, or to put it down to a dealer built car.
I do love the secrecy around the tag and engine numbers, when you consider it had its bonnet up at Warwick, how many people out there would already know the numbers and those in the know about how to "forge a car like this" would have the numbers of it.
Warren
#56 Posted : Friday, 23 December 2016 9:19:18 AM(UTC)
As Warren says. This is the norm until the BODY plate changed. You cannot pick a V8 HK from a 6cyl one from the tags, and once you get to HT you cannot pick a 186S car from a 161 or a 308 or 307 from a 253 powered car by the tags. HQ is no different, look at a 1971 HQ LS V8. There is no way from the tags to know if the car was a 253, 308 or 350. This Kingswood is the same.
Lingus Offline
#57 Posted : Friday, 23 December 2016 11:21:24 AM(UTC)
Lingus
The tags do also tell you that this Kingswood was manufactured with bucket seats, but that in itself doesn't confirm whether the car had a column shift or floor shift transmission.
Looking at images of this car's interior, as displayed on the AMCS website, can anybody clue me in on the floor console ? ... no doubt the car originally featured colour-matched lap/sash seatbelts of the non-inertia type and the buckles would not have been fixed to a stalk but to belts that allowed the buckles to be stowed in the recess at the rear section of the console ... between that recess and the gear lever you will see a perforated section that suggests to me a speaker grille ... I don't recall seeing this feature on any HQ consoles and wonder if it represents a 'police' specification ?
#58 Posted : Friday, 23 December 2016 3:08:04 PM(UTC)
True. Being a V8 Kingswood sedan it could have been column shift manual, column shift auto, console shift auto, console shift manual or floor shift manual. But looking closer the tags do tell you (as already pointed out) it is a 5 seater which rules out floor shift manual, and it has no ADR9 on the ADR tag which mans it is a manual so it is limited to:
253 3spd column shift.
253 console shift 4spd.
253 console shift M21 4spd.
308 M21 4spd.
And in this case, 350 MC7 4spd.
However any further information has to be either gathered from available evidence on the body, or using the PSN have it looked up in GMH original records.
detective Offline
#59 Posted : Friday, 23 December 2016 9:03:50 PM(UTC)
detective
308 M21 4spd.
.....the HQ seat belt buckles sitting in their console pockets were to do with earlier 1971 ADR's.
The introduction of the later on 1972/3 spec inertia reel seat belts were another tweak on the safety aspect... .a fixed stalk female end with the tongued male end on the reel.
Edited by user Friday, 23 December 2016 9:10:01 PM(UTC)  | Reason: Not specified
#60 Posted : Saturday, 24 December 2016 7:09:19 AM(UTC)
Wow. So you are relying on Holden records. Lucky they were not destroyed.
Guest (5)
6 Pages<12345>»
This page was generated in 0.124 seconds.
