2 Pages<12
castellan Offline
#21 Posted : Tuesday, 27 December 2016 12:23:52 PM(UTC)
castellan
What about the 195kW engine?
Being a HSV enhanced / HBD option, it wouldn't get mentioned. Like my VS 2 Calais with the HSV 185i engine - regular books that a 168kw car gets.
No supplement for the different specs?
Nope, only the dedicated Calais sales brochure that mentions it as an option. Regular brochure notes it as an option on SS & Berlina V8 as well, same with Caprice & Stato.
Only specs are in the brochure & HSV compendium.
There's another one - supplement for the VS2 Calais with the Supercharged engine - released 3 months into series 2, but aligned with Stato/Caprice S2.
The VSIII utes sales brochure also has the 195i engine in it as a HBD option.
I have a Series 3 ute sales brochure, at the specifications bit it has a sticker stuck on top of the original with 179KW mentioned, with at the bottom of it saying 179KW engine available in utes manufactured from 1st January 1999 and the same type of sticker stuck on over the top of the powertrain part as well.
No mention of the 195KW in this brochure and I got my ute in Nov 1999 and the 195KW were all gone if I wanted that 195 option, so they informed me at the time.
I have a Olympic edition ute brochure as well with a picture of a sequential 5.0L V8 in it.
Edited by user Tuesday, 27 December 2016 12:30:36 PM(UTC)  | Reason: Not specified
#22 Posted : Tuesday, 27 December 2016 1:23:53 PM(UTC)
I also have a VS III sales brochure, I bought mine in December 2000. My sales brochure is dated July 1999. On the "Features to suit your lifestyle" page, just before the features and specifications section it says:
"Holden's optional 5 litre V8 with sequential fuel injection delivers 179kW of power and 400Nm of torque. Holden also offer for the ardent Ute enthusiast the HBD 195kW High Performance V8".
Also on the features page, 179kW V8 Optional on S, and 195kW V8 Option from HBD.
All specifications also list the sequential injection, knock sensor, 179kW, 400Nm etc.
#23 Posted : Wednesday, 28 December 2016 12:10:34 AM(UTC)
Was thanked: 27 time(s) in 26 post(s)
Bazza here you go
HK June, 1968 Part No. 2805866, Monaro, Has 120MPH Speedo
HK Sept., 1968 Part No. 2805866, Monaro, P3 & 4-Courtesy Lights, P5-Horns, P6-Container
HK Dec., 1968 Part No. 2805866, Monaro, Reverse shift pattern, Last Page Clearance 7"
castellan Offline
#24 Posted : Wednesday, 28 December 2016 11:07:17 AM(UTC)
castellan
My Brochure was printed May 1998 and who ever doctored it, looks like the stick on is from a VT brochure, but it has (*179KW engine available in utes manufactured from 1st January 1999) directly at the bottom of the spec ?
When I bought mine the dealer had a VS Maloo with the 195KW sitting on the show room floor, and I thought I would just get the S ute and open up the exhaust and chip it, if I knew that the 195KW had a different exhaust valve and bigger cam I would of liked to go for that 195KW option for sure, but the dealer said that I could not get the 195KW option at the time because they had run out of them, so that may of just been a lie he said to make the deal easy for him.
I wonder how many 195KW optioned utes were sold, maybe more likely in the special ID series or Olympic edition utes maybe more likely, mine was just an S and just only a work ute and carried river sand in it and that even freaked some people out that I would do such a thing, but I would water that down with, it's better to use this ute then my Caprice don't you think, it's just a ute not a Baby you know.
All the first series 3 VS SS utes were 168KW and the next batch were all 179KW only and they came without the rear sway bar.
#25 Posted : Wednesday, 28 December 2016 11:37:21 AM(UTC)
I've only ever seen one or two 195i VSIII. There was no V8's left when I bought mine, all gone by mid 2000.
All you had to do to a VSIII 179 to make it 195 I think was exhaust, cold air and memcal. I don't think the commercial 195kW got the HSV head changes, Mick might confirm. The 165-185kW was the same add on's but also a knock sensor from memory.
You are right, the earlier VSIII's used the VS's 186kW engine and the V8 engines were stockpiled for VSIII once VT ended. They should have stockpiled more as people still wanted them in later 2000.
#26 Posted : Thursday, 29 December 2016 10:18:48 AM(UTC)
Engine number prefix will tell if it had the head changes or not.
I've only ever seen VS3 Stato/Caprice with the HBD engine option - 2 of them with the regular VS1&2 optional 185i, and one with the 195 with the rounded front cover like the VT.
I think HSV enhanced must have finished before the 179/195 roller 5L, as those 3 were all HBD plated.
castellan Offline
#27 Posted : Thursday, 29 December 2016 12:11:10 PM(UTC)
castellan
I thought the 195KW was just like the old 165KW and 185KW job done at the time, but I found out that the exhaust valve and cam is changed in the 195KW engine, the head is the same and the roller cam is the same as that in the 5.7L Holden V8 in the first VT series.
The head part number maybe different only due to the valve, but the 195KW HBD = HSV engine has to be just that, not a 179KW with just exhaust and chip change on the utes, as the Maloo has the 195KW and this 195KW engine is made by Holden not HSV, only the VT HSV GTS enhanced 230KW optioned 5.7L blue printed HSV is I believe. not to mention the old flat bottom cam 5.7L enhanced in the VS HSV GTS 225KW that was done by HSV.
I know a bloke who had every 5.0L commodore ute and he said that the 168KW one was the most gutless one he had, I don't know if they had a knock sensor, I would not think it needed it as it's just a air box snorkel fitted to a 165KW engine, but if they do then that could count as why he said it lacked power, maybe the timing map was altered a bit to pass ADR.
The V8 Getrag box comes about when the VT sedan comes about from Aug 1997, so that makes it a late series 2 VS ute that gets them, changing gear going from 1st to 2ed real fast can bite your finger on them utes, so you soon learn to change how to do that.
I think that the VU ute was delayed a bit, so the planed stock pile ran short.
The VU rear end arms are not the same as the sedan so Peter Brock informed me, when I was on about the setup of the VT was 3rd rate and I was pointing out that GTS, VX type setup was the way to go, but he said don't do it because the ute arms are a little different to the sedan and wagon.
I was pointing out what a bucked of sh-t the VT SS was, with the rear end habit of wanting to kill you when pushing hard, say 160KM/H plus through tight corners, as the stupid geometry would make the outside wheel toe in too much and the inside wheel toe out to much, so the bastard was steering from the rear setting you up to loose control, the first time I came across this I was heading up to a single lane bridge and some fancy foot work and steering was deployed instantly, I still remember that like it was yesterday and the utes could do the same but not as bad, but with my dirt bike in the back the rear end was fine, I would say that if the rear comes up too high and low because of body roll one rear wheel is toeing one way and the other is doing the same direction as well.
So if the rear wheels are neg camber you have more toe in and if the wheel is at pos camber it has toe out. who want's to debate that subject.
So Brock informed me not to do this VX setup with the utes and non of the utes did, but for some Maloo utes, VZ I think they may have it, but they are not as high load rated and may use the sedan arms. the shocks are all different lengths for the sedan and then the wagons are the shortest and then the ute gest the longest.
2 Pages<12
