Marlin12 Offline
#1 Posted : Sunday, 28 May 2017 2:22:35 PM(UTC)
Marlin12
hi guys
just trying to identify the month year of a 308 block. and what car it came out of if possible
casting number is 9j4 which is located next to the dial and the engine number is 1910621
thanks
#2 Posted : Sunday, 28 May 2017 4:26:32 PM(UTC)
9J4 is 9th September 1974, 1984 or 1994. What is on the sides of the block will give up what year.
Engine # is not a GMH number.
Marlin12 Offline
#3 Posted : Sunday, 28 May 2017 4:35:20 PM(UTC)
Marlin12
sorry my apologises read the number wrong it qt910621
cant see any other numbers on side of block except the 308
Edited by user Sunday, 28 May 2017 4:56:51 PM(UTC)  | Reason: Not specified
#4 Posted : Sunday, 28 May 2017 5:03:57 PM(UTC)
I'd walk away from that one. 12/77-1/78 engine number on a HQ era block (assuming it is a 1974 block not 1984 or 1994).
Marlin12 Offline
#5 Posted : Sunday, 28 May 2017 5:12:22 PM(UTC)
Marlin12
interesting.. how do i confirm its a hq block then, im actually in need of a hq block. as mine is at engine builders and just found out it has a creack between boreBrick wall
#6 Posted : Sunday, 28 May 2017 5:58:00 PM(UTC)
It doesn't matter if HQ engine number has gone.
Marlin12 Offline
#7 Posted : Sunday, 28 May 2017 6:02:33 PM(UTC)
Marlin12
thanks for your help appreciated
#8 Posted : Sunday, 28 May 2017 6:11:17 PM(UTC)
If you want a HQ era block look for cast date in 1971-4. Will all be manual blocks with 308 on one side, and mostly all neoprene rear main seal. Will have QT, 11QT, HT or HZ engine number prefix. You will also find NT and 308N prefixed numbers in this timeframe too. Anything cast from around Exx1 to xxJ4 (xx is day of month) will be HQ era block but be wary of 1983-4 and 1993-4 cast dates. You can't confuse 1981-2 or 1991-2 as 1971-2 are US format date codes.
This page was generated in 1.830 seconds.
