Can anyone tell me if the HJ-WB van upper tailgate fits any earlier vans? Specifically HK-HG
No they won't, they are much taller.
Having side that, I do know that HD/HR/HK/HT/HG van upper tailgates are all the same.
Dr Terry |
I think the glass is the same but as Dr Terry says they are taller. Extra steel between the glass and the bottom. |
Yes, the glass is the same from HD to WB.
Also, a heated rear screen was an option for panel van upper tailgates in the WB series, if you can find one.
Dr Terry |
Originally Posted by: HK1837 I think the glass is the same but as Dr Terry says they are taller. Extra steel between the glass and the bottom. So is the roof isn’t it?
Originally Posted by: wbute Originally Posted by: HK1837 I think the glass is the same but as Dr Terry says they are taller. Extra steel between the glass and the bottom. So is the roof isn’t it? Yes the whole turret panel is the same from HD to WB. Dr Terry |
The roof is essentially the same HK-HG to HQ-WB, they just added extra steel at the bottom which is why the upper tailgate has extra steel too. The turret was extended as well. When you compare HK-HG part numbers for some of the roof inner bits with WB they are still the same numbers. |
