Newby our first HQ project
My son and i are looking for information or a referance drawing/diagram for us to identify if we are buying the correct steel rims for his HQ kingswood.
eg offset, centre bore/spigot, stud size and distance between studs
Genuine Holden steel wheels should have their part number & size stamped. The tyre needs to be removed to see it.
Part no. for the regular 5" x 14" rim is 2815162 (This was the standard Kingwood rim) Part no. for the optional 6"x 14" rim is 2823652 Part no. for the One-Tonner heavy-duty 6" x 14" rim is 2824784 There was also the GTS style 6" x 14" rim & there are a few part numbers for those.
Dr terry |
Thank you DR Terry
Do rims from HJ,HX,HZ series fit on HQ cars
Joined: 6/05/2016(UTC) Posts: 151 Location: SEQld Thanks: 11 times Was thanked: 3 time(s) in 3 post(s)
I believe HQ were the first using Chev stud patterns. Yes...HZ /WB were wider being 6 inch tho...Other more knowledgable chaps here will fill you in on the off sets diff if any.
As above, HQ-WB are the same stud pattern and centre bore. That is why we had US and Canadian made Pontiac Rally rims and the 14x7" poly cast rims, plus the wire rims as options or standard on HQ-WB. |
Thanks for the good info I bought four rims last week, I was told they were HQ unfortunately for me they didn't fit the HQ. I've since learnt they may be early commodore hence all the question, I don't want to fall into the same trap again. Hopefully he will take them back and refund my money
Commodore are very close but don’t fit they had a metric pattern. So many people claim they fit, they don’t.
