CovertHQ Offline
#1 Posted : Tuesday, 30 January 2018 4:02:12 PM(UTC)
CovertHQ
Newby our first HQ project
My son and i are looking for information or a referance drawing/diagram for us to identify if we are buying the correct steel rims for his HQ kingswood.
eg offset, centre bore/spigot, stud size and distance between studs
#2 Posted : Tuesday, 30 January 2018 6:13:17 PM(UTC)
Genuine Holden steel wheels should have their part number & size stamped. The tyre needs to be removed to see it.
Part no. for the regular 5" x 14" rim is 2815162 (This was the standard Kingwood rim)
Part no. for the optional 6"x 14" rim is 2823652
Part no. for the One-Tonner heavy-duty 6" x 14" rim is 2824784
There was also the GTS style 6" x 14" rim & there are a few part numbers for those.
Dr terry
CovertHQ Offline
#3 Posted : Thursday, 1 February 2018 8:34:06 AM(UTC)
CovertHQ
Thank you DR Terry
Do rims from HJ,HX,HZ series fit on HQ cars
griffo Offline
#4 Posted : Thursday, 1 February 2018 9:32:30 AM(UTC)
griffo
Originally Posted by: CovertHQ Go to Quoted Post
Thank you DR Terry
I believe HQ were the first using Chev stud patterns.
Yes...HZ /WB were wider being 6 inch tho...Other more knowledgable chaps here will fill you in on the off sets diff if any.
#5 Posted : Thursday, 1 February 2018 10:13:50 AM(UTC)
As above, HQ-WB are the same stud pattern and centre bore. That is why we had US and Canadian made Pontiac Rally rims and the 14x7" poly cast rims, plus the wire rims as options or standard on HQ-WB.
CovertHQ Offline
#6 Posted : Thursday, 1 February 2018 10:49:54 PM(UTC)
CovertHQ
Thanks for the good info
I bought four rims last week, I was told they were HQ Liar unfortunately for me they didn't fit the HQ.
I've since learnt they may be early commodore hence all the question,
I don't want to fall into the same trap again. Hopefully he will take them back and refund my money
#7 Posted : Friday, 2 February 2018 7:47:30 PM(UTC)
Commodore are very close but don’t fit they had a metric pattern. So many people claim they fit, they don’t.
This page was generated in 0.175 seconds.
