Joined: 2/07/2019(UTC) Posts: 26 Location: Ballarat Thanks: 21 times
Is a six cylinder harness the same as a 253 v8 harness ?
Which harness? Which gearbox? What I mean is the dash harness or the engine harness? Manual and auto differ in the dash harness, plus anything with a sports dash will have ammeter wiring. Edited by user Saturday, 20 July 2019 8:30:39 AM(UTC)
| Reason: Not specified |
As HK1837 has said the harness is not just one piece, it is made in sections. I assume we talking HQ/HJ here.
AFAIK I know there is only one type of rear harness, although there will be variations for wagon, Statesman & ute/van. There will be 2 dash harnesses (manual & auto) & at least 3 engine harness (6, 253/308 & Chev350).
There are 2 front panel harnesses (single & dual headlights).
What do you need to know & what model series are we talking about ?
Dr Terry.
It is HG Terry, see the title line. |
Thanks: 3 times Was thanked: 34 time(s) in 33 post(s)
I presume Garry is asking about an engine harness for an engine swap? They are not the same. Wires to such things as the temp and oil sender, coil, vary in length due to there different locations on 6 v v8. These of course can be adapted by shortening/lengthening as appropriate.
1 user thanked Sandaro for this useful post.
As Sandaro has said the 6 & V8 engine harnesses are different mainly in their length.
There are not that many wires.
From memory:
Dark blue - Oil pressure Dark green - Water temperature Brown - Alternator light Yellow - Ignition +ve (Coil) Purple - Starter solenoid Thick red - Main battery +ve
A few extras that aren't present on all cars: Pink - Heater fan Tan - Brake differential switch (1971 cars) Dk green & Lt green - Reverse switch for 4-speed manuals Extra thick red - Power windows
Also the wiring will vary slightly if you have a sports instrument cluster, for the ammeter, plus the extra brown for the tacho (Coil -ve)
Using some patience you can extend the wiring by soldering & using heat shrink tubing.
Dr Terry |
Thankyou everyone . It is presently has a 186 but I would like to put a 253 in it plus a trimatic .
