VE SS Offline
#1 Posted : Tuesday, 8 October 2019 8:18:02 PM(UTC)
VE SS
I am currently getting a HK back on the road and bought a set of rare spares studs and nuts to replace all the old ones. The nuts are correct taper for HK and the outside diameter is 3/4”. The mechanic who is doing the roadworthy and some other repairs made contact today and is under the impression they should be 13/16”. Can someone confirm what it should be, 3/4 or 13/16 of an inch?
#2 Posted : Wednesday, 9 October 2019 7:05:55 AM(UTC)
Was thanked: 213 time(s) in 194 post(s)
All Holden wheel nuts from FE to WB are 3/4-inch A/F.
The taper changed at HT. FE to HK have the shallow taper & HT to WB have the deeper taper. Threads are all 7/16 UNC.
VE SS Offline
#3 Posted : Wednesday, 9 October 2019 7:45:11 AM(UTC)
VE SS
Thanks Dr Terry!
gm5735 Offline
#4 Posted : Wednesday, 9 October 2019 10:43:01 AM(UTC)
gm5735
I believe the studs and nuts are 7/16" x 20TPI, which is 7/16" UNF, not UNC.
#5 Posted : Wednesday, 9 October 2019 10:44:46 AM(UTC)
You are correct. My typo or was it fat fingers.
This page was generated in 0.444 seconds.
