Joined: 26/06/2019(UTC) Posts: 2 ![Australia Australia]() Location: Victoria
I am currently getting a HK back on the road and bought a set of rare spares studs and nuts to replace all the old ones. The nuts are correct taper for HK and the outside diameter is 3/4”. The mechanic who is doing the roadworthy and some other repairs made contact today and is under the impression they should be 13/16”. Can someone confirm what it should be, 3/4 or 13/16 of an inch?
Thanks: 1 times Was thanked: 242 time(s) in 216 post(s)
All Holden wheel nuts from FE to WB are 3/4-inch A/F.
The taper changed at HT. FE to HK have the shallow taper & HT to WB have the deeper taper. Threads are all 7/16 UNC.
Dr Terry |
Joined: 16/04/2014(UTC) Posts: 768  Location: Victoria Thanks: 1 times Was thanked: 49 time(s) in 47 post(s)
Originally Posted by: Dr Terry  Threads are all 7/16 UNC.
Dr Terry I believe the studs and nuts are 7/16" x 20TPI, which is 7/16" UNF, not UNC.
Originally Posted by: gm5735  Originally Posted by: Dr Terry  Threads are all 7/16 UNC.
Dr Terry I believe the studs and nuts are 7/16" x 20TPI, which is 7/16" UNF, not UNC. You are correct. My typo or was it fat fingers. Dr Terry |
