HK-Q-Z5.0Lfan Offline
#1 Posted : Tuesday, 12 May 2020 1:10:46 PM(UTC)
HK-Q-Z5.0Lfan
G'day
Just asking was there a heavy duty engine mount bracket (one that bolts to the block) of 6 cylinder holdens, HQ -on? I have a pair that came off a very ordinary 6 cyl auto HQ sedan, that are 2 plates welded together. I have owned a few of these cars, worked on a heap, & wrecked a lot & haven't noticed any others the same. There is no additional mounts or bolts that you would expect as was on a/con.
I have had these for ages & never worked out what they were for, so I'd thought I would ask around
Ian
Premier 350 Offline
#2 Posted : Thursday, 14 May 2020 12:19:42 AM(UTC)
Premier 350
I had a HQ Premier, factory air. It was mid 1990s when I pulled the 202 and threw a 350 at it. I don't remember any thing different in the engine mount department.
#3 Posted : Saturday, 16 May 2020 8:56:55 PM(UTC)
HK-Q-Z5.0Lfan
OK, thanks. It's not really important, just something of interest that I had no answer to.
#4 Posted : Sunday, 17 May 2020 7:28:15 AM(UTC)
It might have been an ADR update. GM-H were doing a lot of crash testing & upgrading in those days.
My 1973 LJ Torana has unique engine mounts (the rubber bit) which have a much heftier captive link. They were introduced at the same time the front sheet metal changes, so must be crash related.
These are no longer available, but are interchangeable with the regular HQ-WB, LH-UC & VB-VK mounts.
#5 Posted : Sunday, 17 May 2020 1:50:10 PM(UTC)
HK-Q-Z5.0Lfan
If I was going to guess I would say torana for rally use
8D11PCH2 Offline
#6 Posted : Sunday, 17 May 2020 2:55:13 PM(UTC)
8D11PCH2
Originally Posted by: HK-Q-Z5.0Lfan Go to Quoted Post
G'day
Ian
Yes GMH introduced the reinforced engine mount brackets in January 1973 HQ Holden & LJ Torana production. They were std on all 6cyl Holden & Torana from that point on.
It was all part of ADR 10B compliance from 1/01/1973.
#7 Posted : Sunday, 17 May 2020 8:03:01 PM(UTC)
HK-Q-Z5.0Lfan
OK. Good info thanks. Not sure if it's the same as what I was asking about, I had a look at a LX torana, VB com & WB ute (all 6 cyls), + a box of eng mounts, and none have the same brackets. (as the ones im asking about). Will check some more next weekend
Thank you
8D11PCH2 Offline
#8 Posted : Tuesday, 19 May 2020 11:14:01 PM(UTC)
8D11PCH2
Can you put up a pic of the mount brackets you are referring to?
#9 Posted : Wednesday, 20 May 2020 6:43:22 AM(UTC)
Was thanked: 630 time(s) in 593 post(s)
Might be Bedford.
#10 Posted : Friday, 22 May 2020 1:39:06 PM(UTC)
HK-Q-Z5.0Lfan
I haven't got access to the place where these are, maybe in a couple weeks.
Also never tried to put up pics, so I will have a go , or email them to someone
420chengandrew Offline
#11 Posted : Thursday, 11 June 2020 4:58:39 PM(UTC)
420chengandrew
Hi i'm also working on the same project man and in need of heavy duty engine mount bracket, what kind of bracket did you use and can you send a picture
This page was generated in 0.132 seconds.
