#1 Posted : Friday, 18 December 2020 5:17:58 PM(UTC)
Can you fit 3.36 gears into a 2.6 housing? I knew there were differences in Banjo housings but I am not a HQ to WB Salisbury expert.
#2 Posted : Friday, 18 December 2020 6:51:37 PM(UTC)
yes.. but you need the centre hemisphere (open or LSD) from the 2.60 axle
NOT the one that the 3.36 gear set was on
#3 Posted : Friday, 18 December 2020 8:24:10 PM(UTC)
As above. 2.6 and 2.78 share a hemisphere and the 3.08 to 4.44 another. I have heard though that if fitting 4.44 gears to another housing that sometimes removal of a bit of casting from the housing is required.
#4 Posted : Friday, 18 December 2020 9:54:12 PM(UTC)
thanks
