Can you fit 3.36 gears into a 2.6 housing? I knew there were differences in Banjo housings but I am not a HQ to WB Salisbury expert.
Joined: 6/07/2019(UTC) Posts: 459 ![Australia Australia]() Location: bayside Melbourne Thanks: 292 times Was thanked: 39 time(s) in 38 post(s)
Originally Posted by: Warren Turnbull  Can you fit 3.36 gears into a 2.6 housing? I knew there were differences in Banjo housings but I am not a HQ to WB Salisbury expert. yes.. but you need the centre hemisphere (open or LSD) from the 2.60 axle NOT the one that the 3.36 gear set was on |
Thanks: 1 times Was thanked: 615 time(s) in 582 post(s)
As above. 2.6 and 2.78 share a hemisphere and the 3.08 to 4.44 another. I have heard though that if fitting 4.44 gears to another housing that sometimes removal of a bit of casting from the housing is required. |
