hilta Offline
#1 Posted : Thursday, 24 August 2023 8:49:35 AM(UTC)
hilta
Hi guys, having a mental block! Can someone confirm please, v8 engine mount brackets, is there a left and right or are they both the same? Where they bolt onto the block, From memory both the same but a friend is saying different! Cheers
#2 Posted : Thursday, 24 August 2023 10:37:55 AM(UTC)
The brackets are the same LH & RH, except for factory a/cond cars, where the LH is different.
hilta Offline
#3 Posted : Thursday, 24 August 2023 10:55:40 AM(UTC)
hilta
Thank you
hilta Offline
#4 Posted : Thursday, 24 August 2023 12:22:06 PM(UTC)
hilta
Just one more question, bolt length for bolts into block, are 1 1/4 thread to long?
#5 Posted : Thursday, 24 August 2023 1:12:35 PM(UTC)
Was thanked: 27 time(s) in 27 post(s)
your friend might be thinking Commodore .... there is a LH and RH for the engine mount brackets
Edited by user Thursday, 24 August 2023 1:14:41 PM(UTC)  | Reason: Not specified
#6 Posted : Thursday, 24 August 2023 6:05:47 PM(UTC)
According to HZ parts book they are:
2 per side. Part number 454905. HQ parts book lists 454905 as 3/8", 16tpi, 7/8" long. This is the top and one lower one.
1 per side. Part number 454943. HQ parts book lists 454943 as 7/16", 14tpi, 7/8' long. These are the front lower I think. The thread is bigger so it stands out.
hilta Offline
#7 Posted : Friday, 25 August 2023 8:39:06 PM(UTC)
hilta
Thanks HK1837 on a different note, late Hz Wb v8 clutch pedal, there is a spring in the top of the pedal, are those springs same as on a 6cyl pedal or any other pedal? Or would anyone have one of the springs? Cheers
Edited by user Friday, 25 August 2023 8:43:00 PM(UTC)  | Reason: Not specified
#8 Posted : Saturday, 26 August 2023 8:07:56 AM(UTC)
From memory it is the same. Will look later and see.
