Hi guys, having a mental block! Can someone confirm please, v8 engine mount brackets, is there a left and right or are they both the same? Where they bolt onto the block, From memory both the same but a friend is saying different! Cheers
The brackets are the same LH & RH, except for factory a/cond cars, where the LH is different.
Dr Terry |
Just one more question, bolt length for bolts into block, are 1 1/4 thread to long?
Joined: 6/07/2019(UTC) Posts: 356 Location: bayside Melbourne Thanks: 222 times Was thanked: 27 time(s) in 27 post(s)
Originally Posted by: hilta Hi guys, having a mental block! Can someone confirm please, v8 engine mount brackets, is there a left and right or are they both the same? Where they bolt onto the block, From memory both the same but a friend is saying different! Cheers your friend might be thinking Commodore .... there is a LH and RH for the engine mount brackets Edited by user Thursday, 24 August 2023 1:14:41 PM(UTC)
| Reason: Not specified |
Thanks: 1 times Was thanked: 485 time(s) in 463 post(s)
Originally Posted by: hilta Just one more question, bolt length for bolts into block, are 1 1/4 thread to long? According to HZ parts book they are: 2 per side. Part number 454905. HQ parts book lists 454905 as 3/8", 16tpi, 7/8" long. This is the top and one lower one. 1 per side. Part number 454943. HQ parts book lists 454943 as 7/16", 14tpi, 7/8' long. These are the front lower I think. The thread is bigger so it stands out. |
Thanks HK1837 on a different note, late Hz Wb v8 clutch pedal, there is a spring in the top of the pedal, are those springs same as on a 6cyl pedal or any other pedal? Or would anyone have one of the springs? Cheers Edited by user Friday, 25 August 2023 8:43:00 PM(UTC)
From memory it is the same. Will look later and see. |
