git Offline
#1 Posted : Saturday, 2 October 2010 2:50:23 AM(UTC)
git
Greetings, Looking for a guru who can improve my knowledge on late model Holden ID.
Plate reads VT8VK69-9C1-1PT, L529927, 17I, C60, J073, NOV99, V5W, LN3, M30, GU4
The bits I don't know are the 9C1-1PT on the model line and the V5W on susp.
Cheers.
look out, the guru is coming through...
Big Al Offline
#2 Posted : Saturday, 2 October 2010 6:24:25 AM(UTC)
Big Al
I believe the 9C1 refers to the 'Police Pack', or Police spec or whatever, like the old BT1. Dunno about the rest.
Edit: http://lmgtfy.com/?q=commodore+V5W
#3 Posted : Sunday, 3 October 2010 4:52:00 AM(UTC)
Hi git.
My lists show the following:
8VTVK69 = VT Executive 4-door sedan
9C1-1PT = Nation Police Pack - Base model auto version
L5299297 = Sequence part of VIN
17I = Pewter interior trim
C60 = manual air conditioning
J073 = Heron white exterior paint
Nov 99 = month & year of production
V5W = country pack suspension
LN3 = naturally aspirated 3.8 V6 engine
M30 = 4L60-E 4-speed auto trans
GU4 = 3.08 rear axle ratio
#4 Posted : Sunday, 3 October 2010 9:06:51 AM(UTC)
1PT is the code for dual airbags in a police pack (VT only - it means other things in other models).
#5 Posted : Monday, 4 October 2010 6:09:41 AM(UTC)
Thanks Mick, you are correct. I was having brain fade. Shows you what can happen when you post without checking & rely on pure memory.
1PC = base auto model.
1PT = with airbags.
git Offline
#6 Posted : Wednesday, 6 October 2010 4:54:05 PM(UTC)
git
Thanx muchly Mick & Dr Terry. It was the only ID plate I have collected like this.
