Greetings, Looking for a guru who can improve my knowledge on late model Holden ID.
Plate reads VT8VK69-9C1-1PT, L529927, 17I, C60, J073, NOV99, V5W, LN3, M30, GU4
The bits I don't know are the 9C1-1PT on the model line and the V5W on susp.
Cheers.
look out, the guru is coming through... |
I believe the 9C1 refers to the 'Police Pack', or Police spec or whatever, like the old BT1. Dunno about the rest. Edit: http://lmgtfy.com/?q=commodore+V5W
Hi git.
My lists show the following:
8VTVK69 = VT Executive 4-door sedan 9C1-1PT = Nation Police Pack - Base model auto version L5299297 = Sequence part of VIN 17I = Pewter interior trim C60 = manual air conditioning J073 = Heron white exterior paint Nov 99 = month & year of production V5W = country pack suspension LN3 = naturally aspirated 3.8 V6 engine M30 = 4L60-E 4-speed auto trans GU4 = 3.08 rear axle ratio
When calculating a car restoration budget, be as accurate as you can & then double the final figure. It will be closer to the truth. |
Thanks: 1 times Was thanked: 35 time(s) in 33 post(s)
1PT is the code for dual airbags in a police pack (VT only - it means other things in other models).
Thanks Mick, you are correct. I was having brain fade. Shows you what can happen when you post without checking & rely on pure memory.
1PC = base auto model. 1PT = with airbags.
Thanx muchly Mick & Dr Terry. It was the only ID plate I have collected like this.
