Is there any major differences between auto and manual extractors? If so, what are they? HZ Wagon 253 Edited by user Thursday, 7 October 2010 11:30:49 PM(UTC)
| Reason: Not specified
Difference would be to clear the gearbox! Especially if it was a 308 auto.
yer its a 253 auto i think they come off a 253 manuel
I think they may fit, not 100% sure though and it'll be brand dependant. Trimatic and 3/4 spd use the same inspection cover, same crossmember, same speedo cable so I reckon you are in with a shot at them fitting. From memory the factory pipes were the same too, only the TH400 stuff was different.
iv'e never noticed a difference, i did fit a set from a 253 manual to a 308 TH400 and they fitted, it was close to the box but not too close to cause a problem
Dave,same here,tight but I got them on,I would say different brands could cause problems thou.
Jim in Adelaide.. |
Jim in Adelaide.. |
would it matter about being a colum shift auto?and are the bolts the same as the standard exhurst manifold for the extractors
Column shift may get in the road. Extractors normally use short bolts. Manifold should have some longer ones in the middle for hot box for aircleaner.
i got another set but they are alot longer than the set of extractors and they also wont fit i dont know what im doing wrong
need more info on pipes and the car. T400 column shift cars are the only ones that have trouble. has car got factory a/c? what pipes? tri-y or tuned(4 into 1 collector type)? brand? part number on head plate? length varies on manufacturer as well
the only ones i have had difficulty with is the T400 column shift...
Tuning for Holley carbs in Perth? PM me. |
its a t400 colum shift its hitting on the gear box linkages and the sway bar mounts
TH400 behind a 253? The adapter plate may have changed the geometry too.
sorry i was miss leaded its not a t400 its a standard 3 speed auto i now have them on i had to rebend the gearbox cooling pipes and all is good now.thanks for the help and thanks to classic oz wreck for there help to
