Dick Offline
#1 Posted : Thursday, 7 October 2010 11:30:07 PM(UTC)
Dick
Is there any major differences between auto and manual extractors? If so, what are they?
HZ Wagon 253
Edited by user Thursday, 7 October 2010 11:30:49 PM(UTC)  | Reason: Not specified
#2 Posted : Thursday, 7 October 2010 11:47:34 PM(UTC)
Difference would be to clear the gearbox! Especially if it was a 308 auto.
Dick Offline
#3 Posted : Friday, 8 October 2010 12:27:12 AM(UTC)
Dick
yer its a 253 auto i think they come off a 253 manuel
#4 Posted : Friday, 8 October 2010 1:17:55 AM(UTC)
I think they may fit, not 100% sure though and it'll be brand dependant. Trimatic and 3/4 spd use the same inspection cover, same crossmember, same speedo cable so I reckon you are in with a shot at them fitting. From memory the factory pipes were the same too, only the TH400 stuff was different.
#5 Posted : Friday, 8 October 2010 6:23:55 AM(UTC)
iv'e never noticed a difference, i did fit a set from a 253 manual to a 308 TH400 and they fitted, it was close to the box but not too close to cause a problem
#6 Posted : Saturday, 9 October 2010 1:49:06 AM(UTC)
Dave,same here,tight but I got them on,I would say different brands could cause problems thou.
Dick Offline
#7 Posted : Saturday, 9 October 2010 11:18:49 PM(UTC)
Dick
would it matter about being a colum shift auto?and are the bolts the same as the standard exhurst manifold for the extractors
#8 Posted : Sunday, 10 October 2010 12:15:44 AM(UTC)
Column shift may get in the road. Extractors normally use short bolts. Manifold should have some longer ones in the middle for hot box for aircleaner.
Dick Offline
#9 Posted : Sunday, 10 October 2010 12:26:07 AM(UTC)
Dick
i got another set but they are alot longer than the set of extractors and they also wont fit i dont know what im doing wrong
#10 Posted : Sunday, 10 October 2010 5:15:39 AM(UTC)
need more info on pipes and the car. T400 column shift cars are the only ones that have trouble. has car got factory a/c? what pipes? tri-y or tuned(4 into 1 collector type)? brand? part number on head plate? length varies on manufacturer as well
adam PERTH Offline
#11 Posted : Monday, 11 October 2010 12:35:13 AM(UTC)
adam PERTH
the only ones i have had difficulty with is the T400 column shift...
Tuning for Holley carbs in Perth? PM me.
Dick Offline
#12 Posted : Tuesday, 12 October 2010 5:56:14 AM(UTC)
Dick
its a t400 colum shift its hitting on the gear box linkages and the sway bar mounts
#13 Posted : Tuesday, 12 October 2010 6:54:25 AM(UTC)
TH400 behind a 253? The adapter plate may have changed the geometry too.
Dick Offline
#14 Posted : Wednesday, 13 October 2010 6:07:18 AM(UTC)
Dick
sorry i was miss leaded its not a t400 its a standard 3 speed auto i now have them on i had to rebend the gearbox cooling pipes and all is good now.thanks for the help and thanks to classic oz wreck for there help to
