gabbi1987 Offline
#1 Posted : Saturday, October 23, 2010 1:22:48 AM(UTC)
gabbi1987
Hi, Im female so if u can help please explain in lamans terms. The oil pressure light in my ss (2002 model) keeps coming on, normally after ive driven the car for about 10 minutes it flashes on then back off again. The oil level is normal and normal in colour. Any idea what this could be? and can i drive the car still?
#2 Posted : Saturday, October 23, 2010 7:32:40 AM(UTC)
Faulty sensor.
Dr Terry.
BIGCAV Offline
#3 Posted : Saturday, October 23, 2010 8:42:46 AM(UTC)
BIGCAV
yeah first things first go to your local auto store and pic up a new sendor unit
try that out first, they should be relativly cheap
if it doesnt fix it you may have bigger problems but always check the sender first
#4 Posted : Saturday, October 23, 2010 5:10:42 PM(UTC)
On the Gen 3 V8 it's not a normal oil 'sender' or switch, it is a 3-pin sensor like a TPS & they're priced over $100.
#5 Posted : Saturday, October 23, 2010 8:52:18 PM(UTC)
after-market mechanical oil gauge equals piece of mind in my books?I know its not a "solution"but it'll make you feel better.
as I read somewhere "silly modern cars"..lol
