Fastlane
Holden Forums
Holden Technical Talk
VX SS Oil pressure light coming on and off
Hi, Im female so if u can help please explain in lamans terms. The oil pressure light in my ss (2002 model) keeps coming on, normally after ive driven the car for about 10 minutes it flashes on then back off again. The oil level is normal and normal in colour. Any idea what this could be? and can i drive the car still?
Faulty sensor.
Dr Terry.
When calculating a car restoration budget, be as accurate as you can & then double the final figure. It will be closer to the truth. |
yeah first things first go to your local auto store and pic up a new sendor unit
try that out first, they should be relativly cheap
if it doesnt fix it you may have bigger problems but always check the sender first
On the Gen 3 V8 it's not a normal oil 'sender' or switch, it is a 3-pin sensor like a TPS & they're priced over $100.
after-market mechanical oil gauge equals piece of mind in my books?I know its not a "solution"but it'll make you feel better. as I read somewhere "silly modern cars"..lol Jim in Adelaide.. |
Jim in Adelaide.. |
Fastlane
Holden Forums
