Rutcho Offline
#1 Posted : Saturday, 21 May 2011 9:08:06 PM(UTC)
Rutcho
hi need some help and sorry if question has been asked . i want to put an Auto gearbox into my HG 253 and also hook up the column shift again as the previouse owner cut a hole in the floor . what auto gearbox will bolt on and whats the best i only drive it once a month around sydney . thx
Utility8 Offline
#2 Posted : Saturday, 21 May 2011 9:11:52 PM(UTC)
Utility8
I would say Trimatic, depending on preference, aftermarket floor shifter can be used or go back to column shift. Cost effective & simple install.
utility8
Rutcho Offline
#3 Posted : Saturday, 21 May 2011 9:33:23 PM(UTC)
Rutcho
also i need an auto column do they just swap over ?
dirty davo Offline
#4 Posted : Sunday, 22 May 2011 12:38:52 AM(UTC)
dirty davo
yes its an easy swap.
i have auto columns available if needed & in most colours, & also all th linkages you'l need
yes trimatic is yor best option, but make sure its a right hand shift type from HG or HQ - WB.
as commodore ones are all left shift, they wont suit column shift
i'll be driving up to sydney tuesday & going home wed midday if you need anything delivered
regards DD 0412109239
satanic customs Offline
#5 Posted : Sunday, 22 May 2011 6:44:51 PM(UTC)
satanic customs
has anyone ever successfully modified a column shift linkage to suit commodore trimatic? or will i be the first? i've got an early v8 tri suiting rebuild or a race prepped bob grant automatics tri from a vc ready to go. i know what i want to use
adam PERTH Offline
#6 Posted : Sunday, 22 May 2011 9:42:54 PM(UTC)
adam PERTH
you could by using a HJ-X Statesman factory T400 column auto set up - which runs across the pan to the passenger side.. you would have to modify a little bit..
#7 Posted : Sunday, 22 May 2011 11:14:21 PM(UTC)
It'd be easier to get the trimatic swapped to RH shift.
Rutcho Offline
#8 Posted : Monday, 30 May 2011 5:44:46 AM(UTC)
Rutcho
thxs for the info now for another question is there a way to hook up the column shift to my aussie 4 speed ?
Utility8 Offline
#9 Posted : Monday, 30 May 2011 7:02:26 AM(UTC)
Utility8
Probably, as pretty much anything can be done.
Would it be worth the bother? Probably not.
Edited by user Monday, 30 May 2011 9:16:08 AM(UTC)  | Reason: Not specified
utility8
#10 Posted : Monday, 30 May 2011 5:02:18 PM(UTC)
Not really. But replace the 4spd with an aussie 3spd and it'll work fine.
#11 Posted : Tuesday, 31 May 2011 8:14:40 PM(UTC)
some old nissans had 4spd on the coloum
#12 Posted : Tuesday, 31 May 2011 9:39:29 PM(UTC)
There were quite a few older cars which had a 4-sp on the column, but the gearbox was designed to make this happen.
The problem with the Aussie 4-sp is that the reverse lever is on the left-hand side of the box.
Having said that, I have seen one fitted. The guy connected the two 3-sp rods from the column to give the 4 forward speeds & had a small lever poking thru the floor for reverse.
A bit agricultural, but it worked.
