Fastlane
Holden Forums
Holden Technical Talk
Help With Coosing a auto gearbox HG
hi need some help and sorry if question has been asked . i want to put an Auto gearbox into my HG 253 and also hook up the column shift again as the previouse owner cut a hole in the floor . what auto gearbox will bolt on and whats the best i only drive it once a month around sydney . thx
I would say Trimatic, depending on preference, aftermarket floor shifter can be used or go back to column shift. Cost effective & simple install.
utility8
also i need an auto column do they just swap over ?
yes its an easy swap. i have auto columns available if needed & in most colours, & also all th linkages you'l need yes trimatic is yor best option, but make sure its a right hand shift type from HG or HQ - WB. as commodore ones are all left shift, they wont suit column shift i'll be driving up to sydney tuesday & going home wed midday if you need anything delivered regards DD 0412109239 www.bellarineclassicautos.com.au
has anyone ever successfully modified a column shift linkage to suit commodore trimatic? or will i be the first? i've got an early v8 tri suiting rebuild or a race prepped bob grant automatics tri from a vc ready to go. i know what i want to use
you could by using a HJ-X Statesman factory T400 column auto set up - which runs across the pan to the passenger side.. you would have to modify a little bit.. |
Thanks: 1 times Was thanked: 485 time(s) in 463 post(s)
It'd be easier to get the trimatic swapped to RH shift. |
thxs for the info now for another question is there a way to hook up the column shift to my aussie 4 speed ?
Probably, as pretty much anything can be done. Would it be worth the bother? Probably not. Edited by user Monday, 30 May 2011 9:16:08 AM(UTC)
| Reason: Not specified |
utility8
Not really. But replace the 4spd with an aussie 3spd and it'll work fine. |
some old nissans had 4spd on the coloum
There were quite a few older cars which had a 4-sp on the column, but the gearbox was designed to make this happen. The problem with the Aussie 4-sp is that the reverse lever is on the left-hand side of the box. Having said that, I have seen one fitted. The guy connected the two 3-sp rods from the column to give the 4 forward speeds & had a small lever poking thru the floor for reverse. A bit agricultural, but it worked. Dr Terry |
Fastlane
Holden Forums
