mmazz30 Offline
#1 Posted : Thursday, 26 May 2011 8:40:41 AM(UTC)
mmazz30
Hi all,
Just want to confirm that the front seats on the HJ GTS coupe are based on prem and stato foam size ie more lumber support than a kingswood.
I emailed a trimmer regarding his coupe covers and he said they are based on kingswood foam base.
I am sure they are prem/stato as mine have the "thicker" foam base.
cheers.
mmazz30 Offline
#2 Posted : Saturday, 28 May 2011 6:44:15 PM(UTC)
mmazz30
Bueller,Bueller anyone???
mmazz30 Offline
#3 Posted : Sunday, 26 June 2011 8:58:58 AM(UTC)
mmazz30
Lets try again....
QAZYHQ Offline
#4 Posted : Tuesday, 19 July 2011 11:15:36 PM(UTC)
QAZYHQ
There are alot of difference between the foams on most hq to wb
Because if you have inserts they need an extra rod attached on 3 sides for the recessed effect (houndstooth/herringbone)and a higher outer arc. hq-wb base foams are formed with springs moulded through the foam so your outer shape is what matters most. In the insert case the foams have a split through the foams with the rods clipped to the springs to creat the square patch in the centre. Other flat style bases do not suit this option but could be altered to suit i guess. Hope this helps.
HT307 Offline
#5 Posted : Tuesday, 19 July 2011 11:26:43 PM(UTC)
HT307
If you need more lumber support you could fit a roof rack
#6 Posted : Wednesday, 20 July 2011 2:45:43 AM(UTC)
I think he meant LUMBAR support.
This page was generated in 0.099 seconds.
