Hi all, Just want to confirm that the front seats on the HJ GTS coupe are based on prem and stato foam size ie more lumber support than a kingswood. I emailed a trimmer regarding his coupe covers and he said they are based on kingswood foam base. I am sure they are prem/stato as mine have the "thicker" foam base. cheers.
Bueller,Bueller anyone???
There are alot of difference between the foams on most hq to wb Because if you have inserts they need an extra rod attached on 3 sides for the recessed effect (houndstooth/herringbone)and a higher outer arc. hq-wb base foams are formed with springs moulded through the foam so your outer shape is what matters most. In the insert case the foams have a split through the foams with the rods clipped to the springs to creat the square patch in the centre. Other flat style bases do not suit this option but could be altered to suit i guess. Hope this helps.
If you need more lumber support you could fit a roof rack
I think he meant LUMBAR support.
Dr Terry |
