what can cause a coil to cook? one of the coils to the VR suddenly overheated and before I could turn the ignition off it had cooked. replaced it with a secondhand one and it overheats as well, but I managed to save it.
Replace the DFI module under the coil. These can cause the coil to draw too much current.
Dr Terry |
I had the same issue - burnt 2 coils. The reason was that both of them had resistances in the order of 0.5 Ohms which means that one needs to run a ballast resistor in line to make sure the overall resistance is about 1.2 to 1.5 Ohms.
"I killed the Bank" Andrew Jackson, last words |
