#1 Posted : Wednesday, 13 July 2011 10:25:32 AM(UTC)
what can cause a coil to cook? one of the coils to the VR suddenly overheated and before I could turn the ignition off it had cooked.
replaced it with a secondhand one and it overheats as well, but I managed to save it.
#2 Posted : Wednesday, 13 July 2011 4:54:24 PM(UTC)
Replace the DFI module under the coil. These can cause the coil to draw too much current.
Holden1Tonner Offline
#3 Posted : Thursday, 14 July 2011 3:28:19 AM(UTC)
Holden1Tonner
I had the same issue - burnt 2 coils. The reason was that both of them had resistances in the order of 0.5 Ohms which means that one needs to run a ballast resistor in line to make sure the overall resistance is about 1.2 to 1.5 Ohms.
"I killed the Bank"
Andrew Jackson, last words
This page was generated in 0.022 seconds.
