hk350
I had the stencil made by a local engraving business. Not sure where you are located but if you are interested I can supply their details. I am not familiar with the "pm" process of contacting members but if you send one I can respond with these details.
I will try and attach the detais here of what I sent to them and some photos. As noted in my earlier post they couldn't cut the tailshaft stencil in the material used for the crossmember stencil.
I am interested to know what is stamped on the end of the steering column as I cannot make out these details on my column. Also interested to know what is on the brake booster as I don't recall seeing anything on mine before it was repaired, presuming your car is a HK?
The details of the first stencils are as follows:
Text is: BL These two letters are approximately 23 mm high. The total length of these letters is 33 mm
Below these two letters are the numerals 2805250 These numerals are approximately 15mm high. The total length of these numerals is 80mm which is centred below the
"BL" text with a spacing of 8 mm between the base of the "BL" text and the top of these numerals.
The details of the second stencil is as follows:
Numerals: 37.8 These numerals are approximately 25mm high. The total length of these numerals is 75mm. As noted in the attached photo this is an outline stencil. The outline line-weight is approximately 0.6 or 0.7 mm thick.
Edited by user Sunday, October 4, 2015 11:34:04 PM(UTC)
| Reason: Spelling and problem uploading photos
