Gerard Offline
#1 Posted : Wednesday, 31 December 2014 9:03:54 AM(UTC)
Gerard
This is my car which I have owned since around 1975. I purchased it in Canberra from the original owner for $1500. The car is a factory 5 litre 4 speed, 10 bolt diff with tramp rods. It was a delete stripes (bonnett and boot) Silver mink with black interior. He had used the car to tow his caravan. I resprayed the car and added a HT bonnett and grille back then. Took the car off the road in 1978 and it had been in storage until I frieghted it up here in 2009 and started restoring it in April 2012. Hope these photos come through
Edited by user Saturday, 3 January 2015 10:41:16 PM(UTC)  | Reason: Not specified
Gerard Offline
#2 Posted : Wednesday, 31 December 2014 9:07:49 AM(UTC)
Gerard
I will try to add the correct photos again
Edited by user Saturday, 3 January 2015 10:41:35 PM(UTC)  | Reason: Not specified
Gerard Offline
#3 Posted : Wednesday, 31 December 2014 9:25:34 AM(UTC)
Gerard
307chev Offline
#4 Posted : Monday, 9 February 2015 7:22:28 PM(UTC)
307chev
Was thanked: 2 time(s) in 1 post(s)
Gerard Offline
#5 Posted : Tuesday, 1 September 2015 6:48:57 AM(UTC)
Gerard
These are some photos of around three years progress on the car. https://drive.google.com...drive.google.com/open?id
Edited by user Tuesday, 1 September 2015 7:04:51 AM(UTC)  | Reason: Not specified
Gerard Offline
#6 Posted : Tuesday, 1 September 2015 7:32:27 AM(UTC)
Gerard
Gerard Offline
#7 Posted : Tuesday, 1 September 2015 7:46:41 AM(UTC)
Gerard
gm5735 Offline
#8 Posted : Tuesday, 1 September 2015 9:57:45 AM(UTC)
gm5735
Looking good Gerard. Great job on the suspension crossmember stencilling.
I'll bet it felt good to get that subframe bolted on.
Gerard Offline
#9 Posted : Wednesday, 2 September 2015 5:24:10 PM(UTC)
Gerard
Geoff
Thanks for your comments. It is a turning point to get the two basic body pieces together, makes it seem like a car again rather than a big trolley. The stencil on the crossmember was made from a laser cut polycarb ?? material. Also tried to get one made for the tailshaft but as the original numbers on it are an "outline" (not solid like the crossmember) the laser cutter melted the material due to the width of the outline (only about 1mm max) Seems the latest photos I posted here have gone which is a pity as it takes me a month of Sundays to do it. Will try adding a few more when stripes are done.
hk350 Offline
#10 Posted : Sunday, 4 October 2015 12:14:45 AM(UTC)
hk350
Hi mate, can't get your pics to work but any chance you can let me know who did your stencils? Need to get some made up for my crossmember, column and booster. Thanks.
Gerard Offline
#11 Posted : Sunday, 4 October 2015 10:59:17 PM(UTC)
Gerard
hk350
I had the stencil made by a local engraving business. Not sure where you are located but if you are interested I can supply their details. I am not familiar with the "pm" process of contacting members but if you send one I can respond with these details.
I will try and attach the detais here of what I sent to them and some photos. As noted in my earlier post they couldn't cut the tailshaft stencil in the material used for the crossmember stencil.
I am interested to know what is stamped on the end of the steering column as I cannot make out these details on my column. Also interested to know what is on the brake booster as I don't recall seeing anything on mine before it was repaired, presuming your car is a HK?
The details of the first stencils are as follows:
Text is: BL These two letters are approximately 23 mm high. The total length of these letters is 33 mm
Below these two letters are the numerals 2805250 These numerals are approximately 15mm high. The total length of these numerals is 80mm which is centred below the
"BL" text with a spacing of 8 mm between the base of the "BL" text and the top of these numerals.
The details of the second stencil is as follows:
Numerals: 37.8 These numerals are approximately 25mm high. The total length of these numerals is 75mm. As noted in the attached photo this is an outline stencil. The outline line-weight is approximately 0.6 or 0.7 mm thick.
Edited by user Sunday, 4 October 2015 11:34:04 PM(UTC)  | Reason: Spelling and problem uploading photos
Gerard Offline
#12 Posted : Sunday, 4 October 2015 11:03:45 PM(UTC)
Gerard
Gerard Offline
#13 Posted : Sunday, 4 October 2015 11:25:36 PM(UTC)
Gerard
Gerard Offline
#14 Posted : Sunday, 4 October 2015 11:28:25 PM(UTC)
Gerard
gm5735 Offline
#15 Posted : Sunday, 4 October 2015 11:34:10 PM(UTC)
gm5735
Here's a photo of the column stencil, from a HT, 28th October 1969.
Edited by user Sunday, 4 October 2015 11:49:25 PM(UTC)  | Reason: Not specified
hk350 Offline
#16 Posted : Monday, 5 October 2015 1:01:20 AM(UTC)
hk350
Thanks for the reply mate, yeah the column date is usually within 1 or 2 days of what's on your steering box. And here's a pic of booster stencil
Gerard Offline
#17 Posted : Saturday, 10 October 2015 11:04:40 AM(UTC)
Gerard
JordanT Offline
#18 Posted : Tuesday, 18 July 2017 10:10:41 PM(UTC)
JordanT
United States
Originally Posted by: Gerard Go to Quoted Post
This is my favorite testosterone booster which I have owned since around 1975. I purchased it in Canberra from the original owner for $1500. The car is a factory 5 litre 4 speed, 10 bolt diff with tramp rods. It was a delete stripes (bonnett and boot) Silver mink with black interior. He had used the car to tow his caravan. I resprayed the car and added a HT bonnett and grille back then. Took the car off the road in 1978 and it had been in storage until I frieghted it up here in 2009 and started restoring it in April 2012. Hope these photos come through
Cool pics, can we get an?
Edited by user Tuesday, 6 July 2021 7:16:19 AM(UTC)  | Reason: Not specified
George Samson Offline
#19 Posted : Thursday, 10 August 2017 4:06:50 PM(UTC)
George Samson
United States
Very nice collection and build. Applause
F4sty Offline
#20 Posted : Wednesday, 17 January 2018 1:02:58 PM(UTC)
F4sty
Nice! Great work on that. May I just ask if you have new additions to the restoration?
This page was generated in 0.117 seconds.
