The white sandman ute link is http://www.cardomain.com/ride/804218
I e-mailed the guy about 18 months ago - the 5 white utes thing was something he was told by a friend of a friend of a friend ;-)
Thanks: 1 times Was thanked: 489 time(s) in 466 post(s)
quote: Originally posted by hx-sandman
Hi Byron,
Care to give us a breakdown of how many you have recorded? eg HQ ute 17 HQ Van 34 etc
The numbers recorded so far: HQ: 22 total. 21 vans (2 x 202, 12 x 253, 7 x 308). 1 ute (308 Kingswood). HJ: 19 total. 17 vans (3 x 202, 7 x 253, 7 x 308). 2 utes, 1 x 253 HOLDEN, 1 x 308 Kingswood. HX: 20 total. 19 vans (1 x 202, 5 x 253, 13 x 308). 1 ute (202). HZ: 24 total. 17 vans (6 x 253, 11 x 308). 7 utes (3 x 253, 4 x 308). |
I have another HX ute - thought I sent it to you about a year ago.
HX Coupe Utility 2/77 GVW: 1860kg Seating Capacity: 2 AHX 23563S Model: 8WM80XR Body: 916343-S Trim: 1890-18V Paint: 568-15953 Engine: L31 Trans: M21 RRAxle: GV4 Tyre Placard: 9942991 Description: C78514 - 558kg load
hello there,abit of info! i just removed compliance plates from my hz panelvan and on the back of the plate it has in red ink the number 88 written, has anyone ever seen numbers hidden under the compliance plates etc before ? thanks byron. jam
What are the last two numerals of the VIN number (skinny plate)? Ignore the Z. |
gday byron , the number is 88 lol on the skinny plate. .cheers jam
That is what the 88 on the ADR plate means ie it belongs to that VIN plate. On all HZs the body number on the BODY plate matches the PSN (last letter and numbers minus the suffix off the VIN number eg H989788 where the VIN was 8M70THH989788Z)) on the VIN plate so they must have written the last two digits of the PSN on the back of the ADR plate so there was no mixup. |
verygood thanks byron.this van i have has rust everywhere.i have cut the roof off and was going to try and put another 1 on! do u know any 1 that has done this or do u think it might be easier to look for another shell,rusty all over.any feedback would be most appreciated thanks again jam
Keep in contact with Greg at ClassicOzWreck on 02 49598999. He gets good stuff in all the time. |
thanks byron.another question for you! the shell on hq and wb are they the same as hj hx and z. panel van that is .thanks again jam
All different, except HX/Z are close.
HQ has two types - 1971-?/1974 had side flutes just above and behind the doors. ?/74 to the end of HQ had no side flutes. HQ had HQ plenum. HQ also had no provision for retractable seat belts.
HJ had HQ wiring harness and hence big plug in firewall. Clutch linkage/rat-trap support on firewall is different to HX/Z. Other firewall harness holes differ slightly.
HX/HZ are very close, with only some minor differences. Somewhere in here the acclerator pedal became welded on instead of bolted. Plus later HZs had the two clutch pedal pivot points up under the dash. Second point is for 6cyl full cable clutch setup.
WB have windscreen washer points in the plenum plus no quarter panel lights. Some body bolts became metric thread at some stage in WB - never figured out when and which exactly. |
thanks again byron,im looking for a hz shell if anyone can help cheers jam
can any one tell me what colour sandman decals go with persian sand paint. thank you.
hi there, i think i have a HX sandman ute? built 9-76, AHX 11133S GVM - 2200KG Seating Capacity - 2 model - 8WM80XR BODY - 904055 S TRIM - 1890 - 18V PAINT - 568 - 15953 Tyre Placard - 9942827 eng - L31 trans - M21 raxle - GV4
Any help would be greatly appreciated cheers Tom
Yep. Its an XU3 HX Sandman ute. Slate trim (18V) was only available on a HOLDEN (nee Belmont) if it was a Sandman on Australian destined vehicles. Other base models with black trim got black trim (19V). In NZ however, 18V was standard on all base models. |
Does anyone know how i can get a hold of a build sheet on a Hx Sandman ute as i have just got one and i wanna put it back to original ?
also can you tell me if this is a sandman ute model.. HX8WM80 body no.. 214971-A trim.. 2214-18V paint.. 568-15991 eng.. L32 trans.. M20 rr axle.. GV7 gvw.. 1860kg seating.. 2 8M80RGL364663X
but it doesnt have XX7 on the compliance plate...... and also would you know how i can findout the build sheet specs?
