Hi, Does anyone know when Holden produced its first van with metallic paint? I'm trying to prove a mate either right or wrong. Thanks, Stuart in Qld
Maybe FJ by special order?
From memory the earliest HQ I have recorded in metallic is 12/73 but there were probably earlier one-off examples.
quote: Originally posted by HK1837
Terry, yes for the quarter strips, but the doors, guards and tailgate strips have holes through the panels for the end clips on each strip where a screw holds them from behind. The middlle clips on the panels have studs. I think this is the same from HK eg Kingswood side strips? Plus when you remove paint it is normally obvious where the spot welded studs have been removed by grinder versus if it had none to begin with.
So HZ panelvans also would have had these as identifiers if they were kingswoods, but if a HZ panelvan didn't it wasn't a kingswood, then could it only be a sandman??
Kingswood vans only existed for HX and HZ, I'm not near my stuff at the moment so I'm not sure about strips on HX and HZ Kingsood vans. HOLDEN HX and HZ Kingswood vans don't have strips either whether they are XX7/XU3 or not if that is what you mean?
hi does any one know if the seat winders on an hj sandman are the same as the ones used on the hq sandman
ooowwww yeh! thats what im talkin bout! |
HQ Sandman seats are the same as any other HQ Belmont (or Kingswood for Kingswood XX7) with buckets. Same for HJ. I don't think HQ and HJ are the same though, seats are very different. Best bet is to ask the guys at mysandman.com.au who are actively restoring these models.
done thanks
5/74 4850lbs seats 2 ehq 47813a HQ80270 110105A 1880 -39b 567-15822 L31 m21 GV2
COULD THIS BE A SANDMAN ?
if i was standing over it without looking up the paint code numbers or anything else i would buy it as i think it is one.
Tuning for Holley carbs in Perth? PM me. |
ok just looked up paint code, its cognac metallic. V8 belmont ute too thats a good thing.... B trim code?, tick Y. all good. Tuning for Holley carbs in Perth? PM me. Edited by user Wednesday, 29 September 2010 12:05:09 PM(UTC)
| Reason: Not specified |
I'd say yes. I have never recorded a HQ Belmont commercial in metallic paint outside of the Brisbane plant that I could prove was NOT a Sandman. Only Brisbane appears so far to have broken that rule. Very rare thing to, not many HQ or HJ Belmont Sandman utes recorded at all.
its a panel van and its going cheep at $4300 on carsales.com.au right now i havnt got any more room with 7 cars or id grab it
Is too. Not sure why I thought it was a ute. Makes no difference anyway, I still reckon its a Sandman.
[quote]Originally posted by t-dog
7 cars?, pppfftt. your not trying hard enough! P.S. frank is here and says hello.
Dont the HQ vans have vents behind the doors? This one on carsales doesn't
Mid 74 the vents disappeared, haven't found an exact date although I think there was some discussion on it in this thread.
Leroy
"Planet earth is the asylum to which the rest of the universe sends it's lunatics" Voltaire |
Hi all, Model: HJ8WN80 Trim: 1904-14V Eng: L32 Trans: M20 Seating: 2 Bulid 05-75 GVM 2200 kg Has GTS options. Melbourne build code. Casino blue HJ Kingswood based sandman ute? Any help would be greatly appreciated.
Cameron.
Cameron
I replied to you via PM
This genuine? (looks like it is) http://www.trademe.co.nz/Browse/Listing.aspx?id=360706241One of you buggers from ozzy has just bought it.
Yes it is appears to be a genuine NZ delivered HZ Sandman. I would have bought it if I'd seen it, despite it being a van and not a ute simply because of its rarity and being a TH400 example. |
