Ok 2 questions 1. does any one know what the numbers mean on a vt/vx vin tag in relation to colour mdl etc ?
2. I have a Hj with a f#$ked chassie am changing all parts over to a HX chassie What vin plates do i need to use to get her regestered? because the HX chassie didn't have any on it only my HJ has them.
Hi Glenn i dunno if this will really help you..but.. my HJ ute has HZ chassis numbers and i actually think is a HX chassis. All the Plates on the flywall identufy it as a HJ, and therefore its registered as a Hj.. soo i dunno if its such a big deal..
Put the Hj numbers on the Hx chassis as they are the same chassis.The Hz and Wb both have RTS so if you put an earlier number on these or vice-versa you can tell straight up it has been restamped.
If you are talking about the alloy compliance plates and you are in NSW I think you will find that after 5 years it is not compulsory to have them . Do not quote me on this , but look intoit .
If you email me the VIN code off your vt/vx I will decode it for you. My email is: commodorenut(AT)aol(DOT)com
Info in the VIN only covers the following: model, degree of luxury, model year, engine, and assembly plant.
The VIN number
Thanks for the help guys i relized just after i posted that the vin code wouldn't tell me paint code thats what the other alloy tag has on it i was after the paint code and colout name of the new purple the VY SS's and Crewman utes have any one have thos
Purple Haze is the name of one of the colours.
It's 970L, and the colour is called Cosmo Mica.
I fell it's probably Cosmo Mica, which is coded 970L, However in case you do mean Purple Haze, it's code is 896K.
