bluHJ Offline
#1 Posted : Tuesday, 12 October 2010 7:08:57 PM(UTC)
bluHJ
I've got a VY 'S' pack. Usually the radio turns off once you open the door but this morning it stayed on. After turning it off with the on/off button, the light and time was still illuminated. Has anyone had this problem and managed to solve it?
cheers...bluhj
bluHJ Offline
#2 Posted : Wednesday, 13 October 2010 1:00:17 AM(UTC)
bluHJ
I just got home and tried to see if the ignition switch was sticking on accessory. I took out the key and opened the door. Radio stayed on until I switched the wipers onto intermittent. Then it went off but goes back on when I switch the wipers off. It's got me stumped.
playwme Offline
#3 Posted : Wednesday, 13 October 2010 2:53:51 AM(UTC)
playwme
Did the wipers activate with the key out and the door open?
#4 Posted : Wednesday, 13 October 2010 2:56:02 AM(UTC)
Crook body control module.
Dr Terry.
bluHJ Offline
#5 Posted : Wednesday, 13 October 2010 3:17:03 AM(UTC)
bluHJ
Playwme
Yes they did.
Thanks. Had a feeling after the last post it may be as I heard a sound from behind the dash shortly after and everything was ok. It's working alright now. Are BCM's interchangeable or do you have to get a specific one using the VIN?
cheers...bluHJ
#6 Posted : Wednesday, 13 October 2010 4:27:57 PM(UTC)
seen the movie `christine`your car is alive!
This page was generated in 0.083 seconds.
