I've got a VY 'S' pack. Usually the radio turns off once you open the door but this morning it stayed on. After turning it off with the on/off button, the light and time was still illuminated. Has anyone had this problem and managed to solve it?
cheers...bluhj
I just got home and tried to see if the ignition switch was sticking on accessory. I took out the key and opened the door. Radio stayed on until I switched the wipers onto intermittent. Then it went off but goes back on when I switch the wipers off. It's got me stumped.
Did the wipers activate with the key out and the door open?
Crook body control module.
Dr Terry.
When calculating a car restoration budget, be as accurate as you can & then double the final figure. It will be closer to the truth. |
Playwme Yes they did.
Dr Terry Thanks. Had a feeling after the last post it may be as I heard a sound from behind the dash shortly after and everything was ok. It's working alright now. Are BCM's interchangeable or do you have to get a specific one using the VIN?
cheers...bluHJ
seen the movie `christine`your car is alive!
