Thanks: 5 times Was thanked: 12 time(s) in 10 post(s)
Hi gents, ill need to rip the cover off anyway, but can someone tell me what gearsets were used in hq/wb 6 cyl panelvans?
Was the 4.44 only used in the tonners?
cheers.
11.38@117mph will go quicker
11.34@121mph went quicker and faster, just not quick enough.
now being rebuilt with many more fasts
6-cyl panel vans had 3.36 or 3.55 banjos HQ-HZ (small Salisbury in WB) with 3.08 as a rare 'economy' option.
AFAIK Large Salisbury rear axles (including the 4.44) were never fitted as base equipment to 6-cyl panel vans.
When calculating a car restoration budget, be as accurate as you can & then double the final figure. It will be closer to the truth. |
thanks Doc, ill have a gander for curiosity sake, just trying to avoid getting dirty, lol.
Most Holden's if not all have the ratio embossed in the pinion seal dust cover just behind the yoke.
FNQ HQ GTS/4
FNQ HQ GTS/4
FNQ HQ GTS/4
never accept those as correct because it is a dust seal and if it has been recoed or pinnion seal changed they will put anything on.. going to church makes you no more a christian than standing in a garage makes you a car... www.classicozwreck.com.au |
