#1 Posted : Thursday, 15 July 2004 7:34:42 PM(UTC)
Hi All
Just wondering which plugs I should be running on a 179 with elec ignition, extractors, 320 holley, larger ports.
Should they be the orig eh ones or the VK (to suit dissy) or hotter etc.
Any tips appreciated.
Jason
#2 Posted : Thursday, 15 July 2004 8:14:30 PM(UTC)
use the plugs to suit the EH head use a brand like NGK or AC delco which are available again through some holden/motor trader outlets.
you will find the electronic dizzy will keep the plugs cleaner than the standard unit as far as fuel deposits.
#3 Posted : Thursday, 15 July 2004 8:52:17 PM(UTC)
If you still run the 179 red motor head you'll have no choice as they are a different size plug. HQ onwards used the tapered plug, before that they were a larger non tapered one with a washer used to seal. Remember to bump the gap out to 1.5mm with the
