nineteenfortyeight Offline
#1 Posted : Thursday, 6 February 2020 6:00:12 PM(UTC)
nineteenfortyeight
Hi All,
I have an SB Barina and the alternator has just been replaced. The battery was disconnected during removal and fitting of the new one. After starting it now runs rough and on the screen in the middle of the dash it shows CODE 1. Any clues? It only has 20,000k's on the clock.
TIA.
Ron
48 215
#2 Posted : Friday, 7 February 2020 7:16:46 AM(UTC)
Was thanked: 213 time(s) in 194 post(s)
The "CODE 1" in the middle of the dash is the radio asking for its PIN, because the battery was disconnected.
The rough running could be many things. One of them could be a throttle body re-learn, in which case a quick run around the block may solve.
Other than that, if you still have issues check a few obvious things like a vacuum line or electrical plug that may have been dislodged while fitting the alternator.
If still no result, get someone to plug in a scanner to check for any fault codes.
#3 Posted : Friday, 7 February 2020 8:22:51 AM(UTC)
nineteenfortyeight
Thanks Dr Terry. I'll check it out on Sunday arvo.
Ron
48 215
#4 Posted : Sunday, 9 February 2020 7:47:51 PM(UTC)
nineteenfortyeight
Hi Dr Terry.
I took it for a drive after finding and punching in the Radio Code. It was still running rough when I drove off but after about 5 k's it came right.
Thanks Dr Terry.
Ron
48 215
