Vintage Caravans Offline
#1 Posted : Monday, 9 January 2006 1:29:54 AM(UTC)
Vintage Caravans
A quick question, did the HQ come out with rod style mechanical linkages on the 202 or all cable linkages, id rod style how do I convert to cable????? do I need to change the carby? pedal woudl be different as well I imagine?
Matt
Looking for Old Caravans!!!! especially 1950's ply ones! Thanks!
1962 EK Wagon - Chev SBC & T700, 1962 EK Sedan - Chev SBC & T700,EK Ute - V6 Buick & 5 speed = LOOKING FOR A 1962 EK VAN
Dylan Offline
#2 Posted : Monday, 9 January 2006 3:56:55 AM(UTC)
Dylan
all HQ's has linkage acceletators.
when i converted my HQ to cable i used an HZ pedal, but had to modify it so that it hole was in the right posistion to line up with the triangle plate i made to replace the linkage plate. i have photo's i can email if
#3 Posted : Monday, 9 January 2006 7:31:53 AM(UTC)
Vintage Caravans
Thanks Dylan, would love to see what you have done
vintagecaravans AT iinet DOT net DOT au
with the usual replacements
Matt
#4 Posted : Monday, 9 January 2006 10:06:50 AM(UTC)
When I did the efi conversion I had to go cable. I got a HJ pedal and base, the HJ bolts to the floor so easy to get, later ones are welded. Then I had to cut a side slot in the top of the pedal bit so the efi cable would go in, and I made up a triangle p
#5 Posted : Monday, 9 January 2006 10:08:35 AM(UTC)
Oh yes you do have to change the carbie I am pretty sure the carby body link thingies are not interchangeable but not sure on that.
#6 Posted : Monday, 9 January 2006 11:08:46 AM(UTC)
Vintage Caravans
Thanks John, that is what I was thinking it looks like the cable mounts to a braket screwed into the carby, and to get that bracket I thought I would have to swap carby to get cable.
As for pedal that sounds like an option, rare spe\ares do a commodore s
#7 Posted : Monday, 9 January 2006 11:50:45 AM(UTC)
Hi Matt,
The Qute was already cable converted before I bought her, but I have converted an LJ from linkages to cable. The cable on the Qute comes out just to the right of the triangular bracket for the original linkages.
In the LJ conversion, I simp
Edited by user Monday, 9 January 2006 11:52:14 AM(UTC)  | Reason: Not specified
#8 Posted : Monday, 9 January 2006 1:50:43 PM(UTC)
Vintage Caravans
Thanks Dave as usual a wealth of info! with all this info I should be powering through it in no time!
Will drop an email to Kev and see what he thinks.
Matt
P.S. I also spoke to Extreme Fuel Systems regarding their fully rebuilt carby's and wai
Edited by user Monday, 9 January 2006 1:53:49 PM(UTC)  | Reason: Not specified
ozjason Offline
#9 Posted : Monday, 9 January 2006 6:23:00 PM(UTC)
ozjason
So what are the disadvantages of rod style linkages? I'm actually starting to like them - you can play with revs of the engine just by reaching!
Cable more responsive or something?
Jason.
Dylan Offline
#10 Posted : Monday, 9 January 2006 6:30:11 PM(UTC)
Dylan
i find a cable gives a much better feel, i will email photo's when my dad brings my digital camera back in a couple of hours, i forgot i only had pics of triangle plate and not the pedal.
the total cost of the cable conversion was $0 i got the pedal an
Edited by user Monday, 9 January 2006 6:32:10 PM(UTC)  | Reason: Not specified
This page was generated in 0.113 seconds.
