trubluhq Offline
#1 Posted : Monday, 9 January 2006 7:15:15 AM(UTC)
trubluhq
Ok - if anyone out there knows who at GMH said it Ok to fit HQs with some gooey black sticky sh*t that goes just behind the air vent near the passenger doors - I was his name, address and first born !
It's good stuff too as it kept the rust intact too !! Argh !! I have patched it, removed most of the black sh*t, anti-rusted it and now I have to wait a few months to get some $$$ to fix it properly.
Any ideas where the leak would be in a HQ ? Premier badge ? A hole towards the rear of the roof ?
Cheers John
#2 Posted : Monday, 9 January 2006 9:34:06 AM(UTC)
That would be Mastick John...good stuff too!
No idea on where the water is leaking in though...sorry
Cheers...Dave
#3 Posted : Tuesday, 10 January 2006 12:04:08 AM(UTC)
when i had my VL it used to get water leak in through the gutter channel and the strips. took the strip off, smeared some silicon in the join and it never leaked again
#4 Posted : Tuesday, 10 January 2006 7:33:30 AM(UTC)
Has it got a vinyl roof,possible rust under roof,
also check rear window seal if it is original it will be as hard as rock and leak for sure,to check bang glass with hand on inside
it will move if original seal still fitted.
if it ain't br
trubluhq Offline
#5 Posted : Tuesday, 10 January 2006 8:33:55 AM(UTC)
trubluhq
Hi VZgen
Yes it does have a vinyl roof, and although not removed its in very good nick (so I thought). There are NO rust dribbles on the outside body work which is what I would have suspected if the roof was bad.
There are no leaks or rust stains in
#6 Posted : Wednesday, 11 January 2006 7:24:59 AM(UTC)
Maybe try and put some gunk on the pins on badges
to try and stop leak.
if it ain't broke we can improve it.
Cheers Steve
trubluhq Offline
#7 Posted : Saturday, 14 January 2006 5:37:11 AM(UTC)
trubluhq
This is a THEORY but I think I have found the answer to all the HQ rust probs in those rear arch wells.
HQ's have a black pressure relief valve near the rear door. It diamond shaped with louvres. It allows cabin are to flow in and out via the boot. Nif
#8 Posted : Saturday, 14 January 2006 7:41:29 AM(UTC)
yet anotehr possibility is the rear window seal has deteriorated and needs replacing. Easy enough to check. Give the screen a half decent whack with your fist and believe it or not, you will probably hear the window "rattle". Off with the mouldings, sl
trubluhq Offline
#9 Posted : Saturday, 14 January 2006 9:57:55 AM(UTC)
trubluhq
Hi Dave,
Yes I do agree, but the front AND rear windows were both resealed before rego, 12 months ago. And repainted too !
Cheers J
#10 Posted : Sunday, 15 January 2006 3:27:37 AM(UTC)
Hop in the boot with a torch and get a mate to spray a hose over it and see what happens you should be able to see something.
Cheers Steve
This page was generated in 0.117 seconds.
