#1 Posted : Tuesday, 10 January 2006 5:34:28 AM(UTC)
Im builing up my hg for my hot 186 im also building. I want the car to have a gangsta kind of feel about it. Its going to be black and low. I want to put commodore stud pattern wheels on it. How do i change the stud pattern?
#2 Posted : Wednesday, 11 January 2006 4:51:28 AM(UTC)
How hard whould it be to put a late model commodore diff into the HG? eg VS SS LSD?
#3 Posted : Wednesday, 11 January 2006 6:47:36 AM(UTC)
your better off with a nine inch.
they are alot more easier to put in and are alot stronger and probly cheaper
zac
Nothing beats cubic inches !!!
#4 Posted : Wednesday, 11 January 2006 9:17:02 AM(UTC)
Dunno about that Zac. The BW live axle diffs are pretty strong and cheaper than a 9"...
Cheers...Dave
#5 Posted : Wednesday, 11 January 2006 9:09:49 PM(UTC)
are they easier to put in??? and are they lighter?
sometimes a 9" is a over kill for a six so i have been told!
zac
#6 Posted : Thursday, 12 January 2006 3:42:59 AM(UTC)
Thats why i wanted to try a commodore diff, as a 9 inch would be a bit overkill for the six
#7 Posted : Thursday, 12 January 2006 4:01:48 AM(UTC)
Also a lot more weight in a 9 inch diff,a b/w behind a 6 cyl hg has to be 10 times stronger than banjo diff.
if it ain't broke we can improve it.
Cheers Steve
#8 Posted : Thursday, 12 January 2006 4:28:45 AM(UTC)
ive also been told 9inch diffs chew up a bit of power to, and in this project i need all the power i can get
#9 Posted : Thursday, 12 January 2006 5:08:16 AM(UTC)
If u go the b/w way a vl diff may be correct width which will give u commodore stud pattern at rear and for front if u get undrilled rotors for your model and have them drilled to suit commodore rim
your problem is solved easily.
#10 Posted : Thursday, 12 January 2006 5:44:14 AM(UTC)
How much would a set of undrilled rotors cost for a hg?
#11 Posted : Thursday, 12 January 2006 9:15:11 AM(UTC)
Depends on who you go through man.... I picked up a set of undrilled for my UC for 156bucks the pair!! But thats through a friend who has contacts *Taps on his nose*!! You'd probably get change from $250 for a pair...
Keith
[img]http://memimage.car
#12 Posted : Sunday, 15 January 2006 5:17:10 AM(UTC)
then i just have to get the holes drilled in commodore stud pattern. Easy as
#13 Posted : Sunday, 15 January 2006 7:37:59 AM(UTC)
You may want to consider ftting HQ type disc rotors and calipers,they are a better rotor(vented)also easier to get undrilled,the HG type rotor is seperate to hub,so hub would still have to be modified to suit stud pattern.
#14 Posted : Sunday, 15 January 2006 7:56:25 AM(UTC)
might even consider some how using brakes of a later model commodore, but then i will need a better brake booster
#15 Posted : Sunday, 15 January 2006 8:11:00 AM(UTC)
On EBAY try mr-spares they have a lot of upgrade kits for holden don't know if they do HG can't hurt to look.
Cheers Steve
#16 Posted : Wednesday, 18 January 2006 7:16:48 AM(UTC)
kool thanx
#17 Posted : Friday, 20 January 2006 6:51:25 AM(UTC)
do you think it would be a good idear to put interior out of a vr/vs commodore into the old hg? or would that just be a waste of time?
#18 Posted : Friday, 20 January 2006 7:04:12 AM(UTC)
Bucket seats with headrests for sure vr/vs or maybe even hz/wb type may be easier to fit,I think that would be about all that would fit out of vr/vs
Cheers Steve
#19 Posted : Tuesday, 31 January 2006 7:33:46 AM(UTC)
im thinking leather buckets out of vr/vs
CherryBomb Offline
#20 Posted : Tuesday, 31 January 2006 10:47:29 PM(UTC)
CherryBomb
Hi Mate.
Go the B/W. Make sure you use the 4 pinion and Not the 6 cyl models (early commys) as there a 2 pinion type. Read Weak!
I read a good review on this sort of thing on a web site from a place in Adelaide called phenix Autos? I think thats what th
Never stop being inspired,
This page was generated in 0.169 seconds.
