fuzzypumper Offline
#1 Posted : Thursday, 12 January 2006 10:47:21 AM(UTC)
fuzzypumper
Hi,
I'm wondering if there is a better converter than the OHG X-1 to run in conjuction with an IMPCO 425+4bbrl throttle body?
Ive had this combo running for years on my mild 253 Torana, gas only conversion but was never happy with low rev range driverbility or the 8 battery sacrificing cold cranks it requires to start.
I have installed new diaphrams and springs in the past but these only provided small improvements and where only short lived once the diaphrams stretched and the springs settled.
Should I consider using an Airod 3 stage converter or wont this combo work?
Any suggestions, anyone please?
#2 Posted : Friday, 13 January 2006 8:54:58 PM(UTC)
Gas mixer itself may be too big for engine,impco have a formula to calculate mixer size to engine air flow.
if it ain't broke we can improve it.
Cheers Steve
FastEHHolden Offline
#3 Posted : Friday, 13 January 2006 11:08:48 PM(UTC)
FastEHHolden
i run the same mixer on a 173...yes takes a while to start...and no I don't think its too big.
#4 Posted : Friday, 13 January 2006 11:33:12 PM(UTC)
Will work fine on many motors I had 1x425 on 454 chev,
but due to size on smaller motors not enough vacuum down low which causes hard starting,low venturi speed.
Cheers Steve
fuzzypumper Offline
#5 Posted : Saturday, 14 January 2006 5:21:43 AM(UTC)
fuzzypumper
Yes i suppose it especially doesnt help when there is a performance camshaft involved with far more valve overlap resulting in even lower cranking vacuum.
While i have an electromagnetic primer punching the diaphram on the X-1 it has no guts. I usualy ne
Edited by user Saturday, 14 January 2006 5:26:03 AM(UTC)  | Reason: Not specified
#6 Posted : Saturday, 14 January 2006 7:31:37 AM(UTC)
OHG dont exist any more but there is an australian made exact copy of this convertor available from LPG conversions in tullamarine vic it's called a B2,they closed there bayswater branch down,impco are only available from 1 place in melb called impco tech
bluHJ Offline
#7 Posted : Saturday, 14 January 2006 8:30:06 AM(UTC)
bluHJ
I had a B2 on my VN. Went OK. It was an early conversion so didn't have a primer. There is a plug on the convertor that is 1/8 gas thread. I connected a copper pipe to it via a spare gas solenoid that was activated by a switch. It then went into
Edited by user Saturday, 14 January 2006 8:32:44 AM(UTC)  | Reason: Not specified
fuzzypumper Offline
#8 Posted : Saturday, 14 January 2006 9:53:57 AM(UTC)
fuzzypumper
Thanks for the info and offer Steve.
BluHJ, I also have a cranking activated solenoid vacuum pipe to the throttle body similar to what you described but it no effect. It created no more vacuum than was present in the venturis thus had no effect to sta
Edited by user Saturday, 14 January 2006 9:56:16 AM(UTC)  | Reason: Not specified
bluHJ Offline
#9 Posted : Sunday, 15 January 2006 8:04:27 AM(UTC)
bluHJ
Fuzzy
My solenoids were electric. I just held the momentary on switch for about 5 or so seconds and pressed the throttle. The pressure of the gas made it's own way to the inlet and filled it up with gas. It fired almost straight away. When I fir
fuzzypumper Offline
#10 Posted : Sunday, 15 January 2006 12:45:54 PM(UTC)
fuzzypumper
Sorry forgot to add my vacuum solenoid was also electric but power was only supply via the ignition switch when cranking.
