RussVRute Offline
#1 Posted : Friday, 13 January 2006 8:35:49 AM(UTC)
RussVRute
G'day all,
I need some advice here, I have a set of lowered springs for the tonner, but they are V8 ones that I intended to put in when I put the V8 in at the end of the year, the problem is I need the suspension done now, as the bushes are all shot to pieces, what I need to know is can I have the lowered springs put in while I'm getting the bushes done, or will this somehow adversely affect anything?, as I will have V8 springs but only a 6 cyl engine for about 9 months or so. Any advice appreciated. Thanks.Russ.
Edited by user Friday, 13 January 2006 8:52:44 AM(UTC)  | Reason: Not specified
#2 Posted : Friday, 13 January 2006 11:41:31 PM(UTC)
With the V8 lowered springs fitted the car will sit at normal height with the 6 in it,will ride a bit firmer(not a bad thing)
so it is not a problem but remember to loosen all wishbone rubbers
when u fit the V8 to stop any twisting on rubbers when car s
#3 Posted : Monday, 16 January 2006 10:44:25 AM(UTC)
Also remember to get a wheel alignment when you do put the 8 in her Russ so it is right at the height it usually sits at...
Cheers...Dave
