#1 Posted : Monday, 16 January 2006 12:50:37 AM(UTC)
we pulled a very tired blue 202 which had done about 110 000 k,s on lpg out of an 84 WB ute and slotted in a less fkd red 202 along with changing from a 3 speed on the tree to 4 0n the floor.. all work well no knocks no oil leaks and runs ok on the gas just vavle noise... anyhow i want to see what kind of build we can do for this blue motor it's standard bore, (still has GM hone marks.) the head has been replaced twice with a lpg/ unleaded picked up from repco at a rip off price.... the last one lasted only 18 months hence the swap of motors this time...
so any idea,s would be great i was thinking along the lines of lil more power and tourqe.
basicly i can put together anything i just need the parts or the right parts to do so.
peter_flane Offline
#2 Posted : Monday, 16 January 2006 1:04:31 AM(UTC)
peter_flane
put VK fuel injection on it
#3 Posted : Monday, 16 January 2006 2:06:36 AM(UTC)
C'mon Peter, i would have thought you'd suggest running it on gas with a supercharger!!
My suggestion, get a nice cam from the Crow Cams catalogue and some headwork (along with the usual rebuild stuff). Should go alright! Then get some extractors and
#4 Posted : Monday, 16 January 2006 2:57:22 AM(UTC)
If you get a black VK injected motor you get a (veryclose to) XU1 cam as stock. Except the valve timing is a bit retarded to get better emissions at idle. I don't understand how a motor that has only done 110000 is stuffed. You say the bores still show th
#5 Posted : Monday, 16 January 2006 3:26:24 AM(UTC)
Get rid of the gas that's your first problem,the quality of gas these days is crap its best left for the bbq!!!!!
if it ain't broke we can improve it.
Cheers Steve
#6 Posted : Monday, 16 January 2006 7:56:47 PM(UTC)
nothing wrong wif gas its rated 110 octane better then any pump fuel....
the 110 000 km was how much the car has done since the gas install the moter is high 290 000... the blue head has vavle on no. 2 cyl out of it's seat... theres the power loss.. i'm
peter_flane Offline
#7 Posted : Tuesday, 17 January 2006 2:29:14 AM(UTC)
peter_flane
Definitley get a gas cam, they give you nice smooth torque. That combined with the extra torque of a 202 will certainly give you good towing. My motor had a LPG torque plus cam, stage 3 head when it was first built and it was very smooth. 135 rwhp on the
#8 Posted : Tuesday, 17 January 2006 7:22:13 AM(UTC)
The octane of gas is nowhere near 110 octane these days,u used to be able to run 11.1 comp in the eighties on gas but not these days,to much butane,the octane would be closer to 95 at best,and gas is to inconsistent in quality these days to build decent g
#9 Posted : Tuesday, 17 January 2006 6:19:25 PM(UTC)
any one know of a web site about cams...?
#10 Posted : Wednesday, 18 January 2006 5:39:37 AM(UTC)
Try crow cams they have a catalog on line.
Cheers Steve
#11 Posted : Friday, 20 January 2006 2:07:12 AM(UTC)
peter smol could you tell me more about your build up to get the 135 hp....
peter_flane Offline
#12 Posted : Friday, 20 January 2006 2:46:39 AM(UTC)
peter_flane
It was pretty straight forward.
Red 202, dynamically balanced, gas cam, stage 3 head, Electronic VK Comm dizzy, Holley 350 carby, Torco manifold, Impco high flow LPG mixer, Walker Motorvator extractors, turbo muffler, 2 1/4 " exhaust.
It has all cha
Guest (10)
