#1 Posted : Monday, 16 January 2006 7:19:14 AM(UTC)
I've got a stereo in my HX (a pioneer unit) and whenever I tune into AM frequencies, i get a tone through the speakers that sweeps from a high tone to a low tone continuously. What's up with that? Is it anything to do with interference from the electric system?
trubluhq Offline
#2 Posted : Monday, 16 January 2006 8:43:15 AM(UTC)
trubluhq
Does it make sound with the engine off ?
Does it make the sound with the engine running ?
Does the sound so up and down as you rev it ?
Where did u get the 12V from ? What circuit - colour wire ?
Please answer all questions. (sounds like point
#3 Posted : Monday, 16 January 2006 9:09:36 AM(UTC)
Hey John/
Makes a sound as soon as the radio is turned on. Even with the motor not running.
Occilates at the same rate regardless of engine speed.
No idea - I did not install it. It does not happen on CD or on FM stations.
#4 Posted : Monday, 16 January 2006 9:45:36 AM(UTC)
Sounds like an oscillater going out on the stereo.
#5 Posted : Monday, 16 January 2006 10:27:02 AM(UTC)
So it could be a 12V feed issue?
trubluhq Offline
#6 Posted : Monday, 16 January 2006 6:19:33 PM(UTC)
trubluhq
Hi Spud,
If all u have on is the radio say in ACC mode, and not IGN, you have a bad Pioneer unit.
However if the HX has electronic ignition and you have the ignition set to IGN, and engine not running, maybe u have the 12V coming off the distributor
This page was generated in 0.065 seconds.
