#1 Posted : Thursday, 25 January 2007 2:44:54 AM(UTC)
Hi all,
The ol 250 in the xf is gettin abit tired now days, so i was thinking about doing a convert and fitting a v8. Can anyone suggest a good way to go that requires limited modifications?? Ie 302 or 302efi type or go chev??
Dmax Offline
#2 Posted : Thursday, 25 January 2007 4:36:41 AM(UTC)
Dmax
Easiest way to go is a windsor 302 motor. You have to remember what ever motor you put in has to comply with the emmissions standards of that model car.
Tunnel Rammed 351, It does not get any better
[img]http://i79.photobucket.com/albums/j154/dmax85au
648hp Tunnel Rammed 351, It does not get any better
#3 Posted : Thursday, 25 January 2007 7:46:00 AM(UTC)
Will a 302 use the existing mounts or would i need to have new mounts welded into position?
Paul351xb Offline
#4 Posted : Thursday, 25 January 2007 12:03:26 PM(UTC)
Paul351xb
Before doing anything ring your local RTA and find out what is involved for you to do a swap.
Each State seems to vary on the rules and regs a bit. It's not as simple as just swapping over engines. You will have to put V8 springs and sway bar in the fr
#5 Posted : Thursday, 25 January 2007 6:39:05 PM(UTC)
You also need to change the position where the heater core hoses are at the firewall. They have to move over to the left more to clear the cylinder head
#6 Posted : Friday, 26 January 2007 1:52:26 AM(UTC)
ok, thanks guys.
