HZute-efi-VS5L Offline
#1 Posted : Friday, 26 January 2007 7:18:28 AM(UTC)
HZute-efi-VS5L
My temp gauge is not working as though it should i believe.
how can i test the hz gts temp gauge???
also i will replace the sender just coz i can and then i know its working. what type do i need for the gts dash? the eng is a vs 5L so is it just a standard old red motor one? or will i be able to use a VS one? maybe they are maybe they are not different?
www.stickthisdecals.com.au
#2 Posted : Friday, 26 January 2007 5:33:58 PM(UTC)
You need one that suits the GTS guage, it must be an HJ to WB or LH/LX sender.
From either a 6 cylinder or V8.
To test take wire of sender the guage will go hot or cold, touch on block and guage will go the other way.
Warren
#3 Posted : Friday, 26 January 2007 6:25:20 PM(UTC)
HZute-efi-VS5L
ah cheers for that!! so if i chat to motor traiders or repco or someone like that they should be able to give me a gts temp sender?
ill test the gauge today n make sure that is workin bonza!
cheers!
Jason
