jimbobhtute Offline
#1 Posted : Thursday, 19 January 2006 8:22:52 PM(UTC)
jimbobhtute
Hello to all
Recently I resprayed the HT with Etch, and then primer filler to hide small imperfections on the panels. After the paint dried I noticed that the beautiful job I had done was not in fact that beautiful, and all the tiny scratch marks that I was trying to cover up still came through. My question is, is there any product that I can apply over the new primer to fill these in?? I have been told that you can't use products like stop putty, as these will peel away when applied in quantities more than stone chip size. I don't own a putty spray gun, so can spray that. The scrathes are not real deep, but I don't want to stuff all the hard work done by top coating it. Could I use any other fine putties out there, or do I have to start again??? The scratches are mainly around the Bog patches, with a few pin holes in the bog as well. I know it's probably dew to the sanding technique or lack of, not fine enough paper/ water, but really need to find a fix so I can top coat and get back on the road. Any help with product or ideas would be good
P.s trying to avoid sanding back the etch and primer, and apply over top.
cheers james
1970 HT UTE
1970 Green HT UTE...
#2 Posted : Thursday, 19 January 2006 11:19:34 PM(UTC)
Sand it smooth (which may include more hi-fill primer first) and spray 2-pack primer over the whole car. This will seal it and stop any shrinkage. With acrylic primer and top coat you should really undercoat it and leave it for at least 2-3 weeks to shrin
jimbobhtute Offline
#3 Posted : Friday, 20 January 2006 12:12:26 AM(UTC)
jimbobhtute
So your saying there is no putties or fine fillers available for this purpose???
1970 HT UTE
#4 Posted : Friday, 20 January 2006 1:21:02 AM(UTC)
hard work... with out a putty gun u basicly rubben n fillen untill u get what u want.... a putty gun u could spray the whole car like said above...
peter_flane Offline
#5 Posted : Friday, 20 January 2006 2:42:00 AM(UTC)
peter_flane
Usually the scratches you are trying to get rid of will show through after putting primer filler on. It is all depending how deep the initial scratches were, how thin the primer filler was, how much of it was put on, and also the quality of the product.
jimbobhtute Offline
#6 Posted : Friday, 20 January 2006 3:55:02 AM(UTC)
jimbobhtute
Can you hire putty spray guns??? From melb here south/east
1970 HT UTE
#7 Posted : Friday, 20 January 2006 4:04:17 AM(UTC)
You can spray hi-fill with a normal gun. It's pretty cheap for a 4L tin from any paint shop or even Super Cheap Auto. I ALWAYS use 2-pack primer as stated above, as the last thing I do after getting the whole car straight and smooth. Even if you manage to
jimbobhtute Offline
#8 Posted : Friday, 20 January 2006 4:29:21 AM(UTC)
jimbobhtute
I tried running 2/3 primer/filler 1/3 thinners with the gun, and it got clogged up. It has a 2 on the tip. So do I need a different gun..
1970 HT UTE
peter_flane Offline
#9 Posted : Sunday, 22 January 2006 11:18:13 PM(UTC)
peter_flane
A new cheap putty gun should only cost about $40. Your paint supplier should have them.
jimbobhtute Offline
#10 Posted : Tuesday, 24 January 2006 8:57:48 PM(UTC)
jimbobhtute
Are their any products on the market that behave the same way as standard bog, but have much finer characteristics and used for fine work, like the scrathes of have discussed earlier???
james
1970 HT UTE
peter_flane Offline
#11 Posted : Wednesday, 25 January 2006 12:47:39 AM(UTC)
peter_flane
There is a product called 'fine filler' It is mixed like body filler and is used to fill scratches, chips and small dents like hailstone dents. Made by many different manufacturers. I personally prefer Cams brand fine filler. It can be used on top of pain
jimbobhtute Offline
#12 Posted : Wednesday, 25 January 2006 3:32:32 AM(UTC)
jimbobhtute
cheers peter
1970 HT UTE
Guest (6)
