ChrisHQUTE Offline
#1 Posted : Tuesday, 24 January 2006 8:28:14 PM(UTC)
ChrisHQUTE
G'day fellas does anyone know a good engineer that could pass the ute when it's finished. I dont think a normal inspection station can pass it as the chassis is going to be cut and shut.
Also could anyone tell me the differences between the 307, 327, 350 blocks. I always thought that the blocks were the same but not real positive on that.
Edited by user Tuesday, 24 January 2006 9:45:19 PM(UTC)  | Reason: Not specified
If a man say's something in the woods and there is no women around, is he still wrong?
#2 Posted : Tuesday, 24 January 2006 8:36:52 PM(UTC)
wWhat area are you in?
I think the street machine magazine site has a list of accredited engineers somewhere in it's realm.
EDIT: Here's a link:
http://carpoint.ninemsn....nternallink.asp?id=6659
_______________________
Edited by user Tuesday, 24 January 2006 8:41:00 PM(UTC)  | Reason: Not specified
ChrisHQUTE Offline
#3 Posted : Tuesday, 24 January 2006 9:22:31 PM(UTC)
ChrisHQUTE
Sorry, located southside of Brisbane
CherryBomb Offline
#4 Posted : Tuesday, 31 January 2006 11:45:31 PM(UTC)
CherryBomb
If I recall correctly there where some early 327 blocks that where actually Small journal. (dont Quote me on that) The same as the Rare Chev 302s - Z28s. Thou few and far between know days I would think.
Never stop being inspired,
#5 Posted : Wednesday, 1 February 2006 3:00:08 AM(UTC)
327 and 350 blocks are the same except for the pre 1968 small journal 327 blocks - both the 327 and 350 have a 4" bore. 307's are all large journal, and are a different block to the others. They have a 3 7/8" bore. You can also make a 307 using a post 196
peter_flane Offline
#6 Posted : Wednesday, 1 February 2006 9:50:39 AM(UTC)
peter_flane
If it is sectioned correctly and done so it is of a high quality an well basically undetectable, then you should be fine. If it is obvious like a stretched chassis, then you will need an engineers report.
ChrisHQUTE Offline
#7 Posted : Wednesday, 1 February 2006 8:20:50 PM(UTC)
ChrisHQUTE
I want to put duels under the back so I reckon they will pick it. But it will be done properly, the chassis just has to be narrowed and sleeved where the spring hangers bolt on. Not a real big job but would like to get it complianced for peace of mind if
peter_flane Offline
#8 Posted : Thursday, 2 February 2006 8:03:04 AM(UTC)
peter_flane
Expect to pay at least $800 for an engineers report these days. That's Vic anyway. I know in QLD you have Blue mod plates, and they are not as expensive, but I don't know if chassis mods are included at that level.
I have bolted a Subaru motor (non tur
