#1 Posted : Wednesday, 25 January 2006 2:22:23 AM(UTC)
Well just got off the phone to Holden.
I rang up to see if they could verify that the a car I have is a Sandman. Guy in Holden was helpfull. But confused me more, I am no expert on these car but am learning,
He told me all Sandmans will have the xx7 or xu3 code, or interstingly for me another code was XY5??
Sorry guys if youve read this over at old holdens
He told me there is a lot of cars optioned by the dealers that appeared as genuine Sandmans which arent. Dealers wouldpay less for these optioned up Vans than a orginal Sandman. Also with the Sandmans getting only built in Acacia Ridge and Brisbane(I think I got places right), there was a supply shortage, hence dealers optioning up others to appear a Sandman
I am 80% sure and so is a few others that the van a have brought is a Sandman. But guess will never know for sure now, however if the bloke in Holden is right then I dont have a Sandman.
#2 Posted : Wednesday, 25 January 2006 4:17:02 AM(UTC)
He has little idea of what he is talking about.
He is correct about what the dealers did though. They appear to have often done this to ambulance packs or kingswoods, or often to Belmonts/Holdens.
All Sandmans are XX7 or XU3 (HQ only has XX7) hoewver th
#3 Posted : Wednesday, 25 January 2006 7:18:59 AM(UTC)
Byron,
Guess you will get to see mine in the metal soon. I will be down that way early Feb.
XY5 had me going too.
Lobo
#4 Posted : Wednesday, 25 January 2006 8:17:18 AM(UTC)
I'm pretty sure Sandmans where built at every Holden plant. My mate has a HZ built at Elizabeth . Go to Van Council of Victoria website. They'll have answers to your Sandman queries. Also try some of the other van links ( VCSA ).
Steve
#5 Posted : Wednesday, 25 January 2006 9:45:54 AM(UTC)
i have a Sandman built from the Elizabeth plant. its plated as a belmont. 8WM70. model has the number then a space then the letter A.Acacia Ridge were XX7 and builders option was XU3. light truck tyres. Some vans plate look like 8W M 70 were to be kingswo
Rhys Offline
#6 Posted : Wednesday, 25 January 2006 8:27:41 PM(UTC)
Rhys
Hi Guys,
what number is it that you ring to find out from Holden the details like you've mentioned here?
Rhys
crowe Offline
#7 Posted : Sunday, 29 January 2006 12:32:12 AM(UTC)
crowe
You need to post your vin No and trim code, What modle and year? It should have the following (HZ)
- 8WM70
- 253 or 308
- chrome door scuffs with short extension.
- 4 head lights (outer low beam
#8 Posted : Sunday, 29 January 2006 8:17:15 AM(UTC)
Its a HX, 7-77
Why would you need VIN?
Seating Capacity 2
GVW 2200
Other codes are
Tyre Placard
185SR14
195SR14
F78S14
FR78S14
Model HX8W M 70
Trim 1894-67V
Paint 567-15940
Eng L31
Trans M21
Diff GV4
It has chrome door scuffs
Edited by user Sunday, 29 January 2006 8:19:09 AM(UTC)  | Reason: Not specified
crowe Offline
#9 Posted : Monday, 30 January 2006 5:19:13 AM(UTC)
crowe
Well with what you replyed with I'd say its a sandman alright.
#10 Posted : Monday, 30 January 2006 7:36:51 AM(UTC)
It's one of those 'in-between' cars. If it's a Sandman it's an XU3. The original rear attachment for the hoodlining and the coutesy light switches are the best indicators, but you can never tell for sure. My original estimation was about 90% sure it's a S
#11 Posted : Monday, 30 January 2006 11:07:16 PM(UTC)
Its a Sandman.M 70 gave it away. HX-HZ models are all most the same. Sandmans had kingswood trims and seats. the hood lining is good. from factory all were buckskin in colour unless asked for black. i have only seen 2 vans with black factory hood linings.
#12 Posted : Tuesday, 31 January 2006 3:23:03 AM(UTC)
It's not a 100% gurantee that it is a Sandman. M70 simply means HOLDEN or base model panel van. If it had another trim code then you could tell for sure, but it is IMPOSSIBLE to tell from those particular ID plates that it is definitely a Sandman. Full le
#13 Posted : Tuesday, 31 January 2006 10:03:20 AM(UTC)
Byron,in the Holden book i have states that the vans with 8WN70 is a kingwood, Sandmands were plated as a Belmont 8WM70 from the HQ days. I know the Belmont stopped after the HQ but the Sandmans kept that i.d. Remember that HQ-HZ Sandmans were made from l
#14 Posted : Tuesday, 31 January 2006 7:33:05 PM(UTC)
Whoa. I don't know where you get your info from but it's almost all myth!
Yes the N70 is a Kingswood, and was only available on HX and HZ. However, the N80 (Kingswood ute) was available from HQ to WB and there were HQ and HJ Kingswood Sandman utes. Even
This page was generated in 0.099 seconds.
