#1 Posted : Friday, 27 January 2006 9:05:49 PM(UTC)
i found a dizz on ebay.
http://cgi.ebay.com.au/E...DVWQQrdZ1QQcmdZViewItem
if i was to buy this what other parts would i need to buy to complete the setup and are the additional part pricey or what?
thanks steve
ozchevy Offline
#2 Posted : Friday, 27 January 2006 9:26:39 PM(UTC)
ozchevy
Nothing, but a new set of HT Leads.
#3 Posted : Saturday, 28 January 2006 12:17:13 AM(UTC)
thanks ozchevy,is it as simple as unpluging my leads pluging in the new ones? then i have to get it re graphed yeah?
Dylan Offline
#4 Posted : Saturday, 28 January 2006 1:07:10 AM(UTC)
Dylan
no, the terminals on the leads are different to points ignition. you will also need a coil to suit electronic ignition. check condition of contacts in cap and on rotor
ozchevy Offline
#5 Posted : Saturday, 28 January 2006 8:47:28 AM(UTC)
ozchevy
Correct me if I'm wrong, but when I looked at the auction, it said removed from a Red Motor, therefor no changes or alterations to wiring would be required. (Already done)
#6 Posted : Saturday, 28 January 2006 8:58:07 AM(UTC)
You will need 12 volts at coil + to do this you will need to run a new wire back to ignition switch or run a relay,the original wire only has 8-9 volts at coil.
if it ain't broke we can improve it.
Cheers Steve
#7 Posted : Saturday, 28 January 2006 10:19:45 PM(UTC)
thanks for your help guys maybe if i do buy one i'll post again about wiring one up coz i'm confused
