TAF Offline
#1 Posted : Monday, 30 January 2006 3:35:47 AM(UTC)
TAF
Looking to fit a 450 econo to my standard 253 red motor work ute and just wanting some advice on jet sizes.
ozchevy Offline
#2 Posted : Monday, 30 January 2006 5:30:43 AM(UTC)
ozchevy
What is the Holley specific Part number of the Carby?
I have a list of all jet sizes for most models available.
#3 Posted : Monday, 30 January 2006 5:41:27 AM(UTC)
The part # is 4500 economiser
ozchevy Offline
#4 Posted : Monday, 30 January 2006 8:10:31 AM(UTC)
ozchevy
You say this is fitted to a 253 cu" engine.
Mate, you must have some great breathing heads on that thing, cause the 4500 is 750cfm and jets range between 66 thou and 100 thou for that model carburettor. Personally I think your've over carburetted the e
TAF Offline
#5 Posted : Monday, 30 January 2006 8:34:59 AM(UTC)
TAF
The info that I've received this carbie is inbetween the 350 and 465 Holley.
ozchevy Offline
#6 Posted : Monday, 30 January 2006 10:02:11 AM(UTC)
ozchevy
Just check the P/No again if you see a number like this 65-7448 or this 65-4412, then this is the Holley Part Number, 4500 is a model number in the series of carburerrors and in the range of the 4500 series there are about eight carburettors from 750 cfm
TAF Offline
#7 Posted : Monday, 30 January 2006 9:21:31 PM(UTC)
TAF
Yeah that's right Ozchevy
ozchevy Offline
#8 Posted : Tuesday, 31 January 2006 2:02:55 AM(UTC)
ozchevy
2bbl Holley carb main jets range in size from 64 thou - 99 thou. Those are your limits. Available in an assortment kit P/No 36-181 Will jet the following carby's,
2010
2300
4010
4011
4150
4160
4500
#9 Posted : Tuesday, 31 January 2006 7:36:55 AM(UTC)
The 450 Economiser carb is not a normal Holley and, IIRC, was made by Weber for Holley.
They are sold as an economy carb for 455 CID Cadillac or Buick (I can't remember which) V8's...
It is a 4 barrel with the float bowl in the centre of the carb be
Guest (7)
